Datasheet Wago 2606-1107/020-000 — Даташит
Серия2606
Модель2606-1107/020-000
Клеммная колодка для печатной платы; рычаг; 6 мм²; Шаг контактов 7,5 мм; 7-полюсный; Push-in CAGE CLAMP
2606-1107/020-000
Actuating element colororange
Actuation typeLever
Цветgray
Contact platingtin-plated
Country of originDE
Габариты: глубина24.3 mm / 0.957 inch
Drilled hole diameter (tolerance)2(+ 0.1) мм
Fine-stranded conductor0.2 … 10 mm² / 24 … 8 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 6 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 … 6 mm²
Fine-stranded conductor, with twin ferrule0.25 … 2.5 mm²
GTIN4055143586467
Height28 mm / 1.102 inch
Height from the surface24 mm / 0.945 inch
Material groupI
Number of Poles7
Number of connection types1
Number of levels1
PCB contactTHT
Pin spacing7.5 mm (0.295 inch)
Rated current41 A
Rated impulse voltage (II / 2)8 kV
Rated impulse voltage (III / 2)8 kV
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)1000 В
Rated voltage (III / 3)800 В
Solder pin arrangementover the entire terminal strip, staggered
Solder pin dimensions1.5 x 1.2 mm
Solder pin length4 мм
Solid conductor0.2 … 10 mm² / 24 … 8 AWG
Strip length11 … 13 mm / 0.43 … 0.51 Inch
Total number of connection points7
Total number of potentials7
Вес26.662 г
Ширина55.35 mm / 2.179 inch
  • PCB Interconnect
26061107/020000, 2606 1107/020 000
На английском языке: Datasheet Wago 2606-1107/020-000
