Datasheet Wago 2616-1111/020-000 — Даташит
Серия2616
Модель2616-1111/020-000
Клеммная колодка для печатной платы; рычаг; 16 мм²; Шаг контактов 10 мм; 11-полюсный; Зажим Push-in CAGE CLAMP
Actuating element colororange
Actuation typeLever
Цветgray
Contact platingtin-plated
Country of originDE
Габариты: глубина32 mm / 1.26 inch
Drilled hole diameter (tolerance)1.7(+ 0.1) мм
Fine-stranded conductor0.75 … 25 mm² / 18 … 4 AWG
Fine-stranded conductor with ferrule with plastic collar0.75 … 16 mm²
Fine-stranded conductor with ferrule without plastic collar0.75 … 16 mm²
Fine-stranded conductor, with twin ferrule0.75 … 6 mm²
GTIN4055143707497
Height37.2 mm / 1.465 inch
Height from the surface33.2 mm / 1.307 inch
Material groupI
Number of Poles11
Number of connection types1
Number of levels1
Number of solder pins per potential3
PCB contactTHT
Packaging typeBOX
Pin spacing10 mm (0.394 inch)
Rated current76 A
Rated impulse voltage (II / 2)8 kV
Rated impulse voltage (III / 2)8 kV
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)1000 В
Rated voltage (III / 3)1000 В
Solder pin arrangementover the entire terminal strip, staggered
Solder pin dimensions1.2 x 1.2 mm
Solder pin length4 мм
Solid conductor0.75 … 16 mm² / 18 … 4 AWG
Strip length18 … 20 mm / 0.71 … 0.79 Inch
Total number of connection points11
Total number of potentials11
Вес100.611 г
Ширина112.8 mm / 4.441 inch
  • PCB Interconnect
26161111/020000, 2616 1111/020 000
На английском языке: Datasheet Wago 2616-1111/020-000
