Datasheet Wago 2616-3103/020-000 — Даташит
Клеммная колодка для печатной платы; рычаг; 16 мм²; Шаг контактов 10 мм; 3-полюсный; Push-in CAGE CLAMP
|  Купить 2616-3103/020-000 на РадиоЛоцман.Цены — от 1 274 до 2 066 ₽ 7 предложений от 4 поставщиков Клеммные Колодки типа Провод-плата | |||
| 2616-3103/020-000 Wago | 1 274 ₽ | ||
| 2616-3103/020-000 Wago | от 1 678 ₽ | ||
| 2616-3103/020-000 Wago | 2 066 ₽ | ||
| 2616-3103/020-000 Wago | по запросу | ||
| Actuating element color | orange |
| Actuation type | Lever |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Conductor entry angle to the PCB | 90 ° |
| Connection technology | Push-in CAGE CLAMP® |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | DE |
| Габариты: глубина | 29.4 mm / 1.157 inch |
| Drilled hole diameter (tolerance) | 1.7(+ 0.1) мм |
| Fine-stranded conductor | 0.75 … 25 mm² / 18 … 4 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.75 … 16 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.75 … 16 mm² |
| Fine-stranded conductor, with twin ferrule | 0.75 … 6 mm² |
| GTIN | 4055143692816 |
| Height | 38.2 mm / 1.504 inch |
| Height from the surface | 34.2 mm / 1.346 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 3 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 3 |
| PCB contact | THT |
| Packaging type | BOX |
| Pin spacing | 10 mm (0.394 inch) |
| Rated current | 76 A |
| Rated impulse voltage (II / 2) | 8 kV |
| Rated impulse voltage (III / 2) | 8 kV |
| Rated impulse voltage (III / 3) | 8 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 1000 В |
| Rated voltage (III / 3) | 1000 В |
| Solder pin arrangement | over the entire terminal strip, staggered |
| Solder pin dimensions | 1.2 x 1.2 mm |
| Solder pin length | 4 мм |
| Solid conductor | 0.75 … 16 mm² / 18 … 4 AWG |
| Strip length | 18 … 20 mm / 0.71 … 0.79 Inch |
| Total number of connection points | 3 |
| Total number of potentials | 3 |
| Вес | 28.108 г |
| Ширина | 32.8 mm / 1.291 inch |
Серия: 2616 (26)
- 2616-1101 2616-1102/020-000 2616-1102/020-023 2616-1103/020-000 2616-1104/020-000 2616-1105/020-000 2616-1105/020-015 2616-1106/020-000 2616-1107/020-000 2616-1108/020-000 2616-1109/020-000 2616-1110/020-000 2616-1111/020-000 2616-1112/020-000 2616-3101 2616-3102/020-000 2616-3103/020-000 2616-3104/020-000 2616-3105/020-000 2616-3106/020-000 2616-3107/020-000 2616-3108/020-000 2616-3109/020-000 2616-3110/020-000 2616-3111/020-000 2616-3112/020-000
- PCB Interconnect
26163103/020000, 2616 3103/020 000
