Datasheet Wago 2616-3110/020-000 — Даташит
Серия2616
Модель2616-3110/020-000
Клеммная колодка для печатной платы; рычаг; 16 мм²; Шаг контактов 10 мм; 10-полюсный; Зажим Push-in CAGE CLAMP
2616-3110/020-000
Actuating element colororange
Actuation typeLever
Цветgray
Conductor entry angle to the PCB90 °
Contact platingtin-plated
Country of originDE
Габариты: глубина29.4 mm / 1.157 inch
Drilled hole diameter (tolerance)1.7(+ 0.1) мм
Fine-stranded conductor0.75 … 25 mm² / 18 … 4 AWG
Fine-stranded conductor with ferrule with plastic collar0.75 … 16 mm²
Fine-stranded conductor with ferrule without plastic collar0.75 … 16 mm²
Fine-stranded conductor, with twin ferrule0.75 … 6 mm²
GTIN4055143707671
Height38.2 mm / 1.504 inch
Height from the surface34.2 mm / 1.346 inch
Material groupI
Number of Poles10
Number of connection types1
Number of levels1
Number of solder pins per potential3
PCB contactTHT
Packaging typeBOX
Pin spacing10 mm (0.394 inch)
Rated current76 A
Rated impulse voltage (II / 2)8 kV
Rated impulse voltage (III / 2)8 kV
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)1000 В
Rated voltage (III / 3)1000 В
Solder pin arrangementover the entire terminal strip, staggered
Solder pin dimensions1.2 x 1.2 mm
Solder pin length4 мм
Solid conductor0.75 … 16 mm² / 18 … 4 AWG
Strip length18 … 20 mm / 0.71 … 0.79 Inch
Total number of connection points10
Total number of potentials10
Вес90.87 г
Ширина102.8 mm / 4.047 inch
  • PCB Interconnect
26163110/020000, 2616 3110/020 000
На английском языке: Datasheet Wago 2616-3110/020-000
