Datasheet Wago 2624-1102/000-004 — Даташит
Клеммная колодка для печатной платы; 4 мм²; Шаг контактов 5 мм; 2-полюсный; Зажим Push-in CAGE CLAMP
| PCB TERMINAL BLOCK; 4 MM; PIN SP | |||
| 2624-1102/000-004 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | black |
| Conductor entry angle to the PCB | 90 ° |
| Connection technology | Push-in CAGE CLAMP® |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | DE |
| Габариты: глубина | 16.3 mm / 0.642 inch |
| Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
| Fine-stranded conductor | 0.2 … 6 mm² / 24 … 10 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 2.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fine-stranded conductor, with twin ferrule | 0.25 … 1.5 mm² |
| GTIN | 4055143762144 |
| Height | 19.4 mm / 0.764 inch |
| Height from the surface | 15.4 mm / 0.606 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 2 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Packaging type | BOX |
| Pin spacing | 5 mm (0.197 inch) |
| Rated current | 41 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 400 В |
| Rated voltage (III / 3) | 320 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solder pin dimensions | 0.8 x 1 mm |
| Solder pin length | 4 мм |
| Solid conductor | 0.2 … 6 mm² / 24 … 10 AWG |
| Strip length | 10 … 12 mm / 0.39 … 0.47 Inch |
| Total number of connection points | 2 |
| Total number of potentials | 2 |
| Type of mounting | Feed-through mounting |
| Вес | 3.39 г |
| Ширина | 11.5 mm / 0.453 inch |
Серия: 2624 (75)
- 2624-1101 2624-1102 2624-1102/000-004 2624-1103 2624-1103/000-004 2624-1104 2624-1104/000-004 2624-1105 2624-1105/000-004 2624-1106 2624-1107 2624-1108 2624-1109 2624-1110 2624-1111 2624-1112 2624-1302 2624-1303 2624-1304 2624-1305 2624-1306 2624-1307 2624-1308 2624-1309 2624-1310 2624-1311 2624-1312 2624-1502 2624-1503 2624-1504 2624-1504/000-004 2624-1505 2624-1506 2624-1507 2624-1508 2624-1509 2624-1510 2624-1511 2624-1512 2624-3101 2624-3102 2624-3102/000-004 2624-3103 2624-3104 2624-3105 2624-3106 2624-3107 2624-3108 2624-3109 2624-3110 2624-3111 2624-3112 2624-3114 2624-3302 2624-3303 2624-3304 2624-3305 2624-3306 2624-3307 2624-3308 2624-3309 2624-3310 2624-3311 2624-3312 2624-3502 2624-3503 2624-3504 2624-3505 2624-3506 2624-3507 2624-3508 2624-3509 2624-3510 2624-3511 2624-3512
- PCB Interconnect
26241102/000004, 2624 1102/000 004
