Datasheet Wago 2624-1311 — Даташит
Серия2624
Модель2624-1311
Клеммная колодка для печатной платы; 4 мм²; Шаг контактов 7,5 мм; 11-полюсный; Зажим Push-in CAGE CLAMP
Actuation typeOperating tool
Цветgray
Contact platingtin-plated
Country of originDE
Габариты: глубина16.3 mm / 0.642 inch
Drilled hole diameter (tolerance)1.3(+ 0.1) мм
Fine-stranded conductor0.2 … 6 mm² / 24 … 10 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 2.5 mm²
Fine-stranded conductor, with twin ferrule0.25 … 1.5 mm²
Fire load0.308 MJ
GTIN4055143578523
Height19.4 mm / 0.764 inch
Height from the surface15.4 mm / 0.606 inch
Material groupI
Number of Poles11
Number of connection types1
Number of levels1
PCB contactTHT
Pin spacing7.5 mm (0.295 inch)
Rated current41 A
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)630 В
Rated voltage (III / 3)630 В
Solder pin dimensions0.8 x 1 mm
Solder pin length4 мм
Solid conductor0.2 … 6 mm² / 24 … 10 AWG
Strip length10 … 12 mm / 0.39 … 0.47 Inch
Total number of connection points11
Total number of potentials11
Type of mountingFeed-through mounting
Вес20.39 г
Ширина81.5 mm / 3.209 inch
  • PCB Interconnect
26241311, 2624 1311
На английском языке: Datasheet Wago 2624-1311
