Оптопары и оптореле Megawin
Datasheet Wago 2624-1511 — Даташит
Серия2624
Модель2624-1511
Клеммная колодка для печатной платы; 4 мм²; Шаг контактов 11,5 мм; 11-полюсный; Зажим Push-in CAGE CLAMP
Actuation typeOperating tool
Цветgray
Contact platingtin-plated
Country of originDE
Габариты: глубина16.3 mm / 0.642 inch
Drilled hole diameter (tolerance)1.3(+ 0.1) мм
Fine-stranded conductor0.2 … 6 mm² / 24 … 10 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 2.5 mm²
Fine-stranded conductor, with twin ferrule0.25 … 1.5 mm²
Fire load0.308 MJ
GTIN4055143578691
Height19.4 mm / 0.764 inch
Height from the surface15.4 mm / 0.606 inch
Material groupI
Number of Poles11
Number of connection types1
Number of levels1
PCB contactTHT
Pin spacing11.5 mm (0.453 inch)
Rated current41 A
Rated impulse voltage (II / 2)8 kV
Rated impulse voltage (III / 2)8 kV
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)1000 В
Rated voltage (III / 3)1000 В
Solder pin dimensions0.8 x 1 mm
Solder pin length4 мм
Solid conductor0.2 … 6 mm² / 24 … 10 AWG
Strip length10 … 12 mm / 0.39 … 0.47 Inch
Total number of connection points11
Total number of potentials11
Type of mountingFeed-through mounting
Вес26.19 г
Ширина121.5 mm / 4.783 inch
  • PCB Interconnect
26241511, 2624 1511
На английском языке: Datasheet Wago 2624-1511
