Линейка продуктов KEEN SIDE
Datasheet Wago 2626-3112/020-000 — Даташит
Серия2626
Модель2626-3112/020-000
Клеммная колодка для печатной платы; 6 мм²; Шаг контактов 7,5 мм; 12-полюсный; Зажим Push-in CAGE CLAMP
2626-3112/020-000
Actuation typeOperating tool
Цветgray
Conductor entry angle to the PCB90 °
Contact platingtin-plated
Country of originDE
Габариты: глубина18.5 mm / 0.728 inch
Drilled hole diameter (tolerance)2(+ 0.1) мм
Fine-stranded conductor0.2 … 10 mm² / 24 … 8 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 6 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 … 6 mm²
Fine-stranded conductor, with twin ferrule0.25 … 2.5 mm²
GTIN4055143587402
Height28.2 mm / 1.11 inch
Height from the surface24.2 mm / 0.953 inch
Material groupI
Number of Poles12
Number of connection types1
Number of levels1
PCB contactTHT
Pin spacing7.5 mm (0.295 inch)
Rated current41 A
Rated impulse voltage (II / 2)8 kV
Rated impulse voltage (III / 2)8 kV
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)1000 В
Rated voltage (III / 3)800 В
Solder pin arrangementover the entire terminal strip, staggered
Solder pin dimensions1.5 x 1 mm
Solder pin length4 мм
Solid conductor0.2 … 10 mm² / 24 … 8 AWG
Strip length13 … 15 mm / 0.51 … 0.59 Inch
Total number of connection points12
Total number of potentials12
Type of mountingFeed-through mounting
Вес45.228 г
Ширина91.8 mm / 3.614 inch
  • PCB Interconnect
26263112/020000, 2626 3112/020 000
На английском языке: Datasheet Wago 2626-3112/020-000
