Datasheet Wago 2636 — Даташит
| Производитель | Wago |
| Серия | 2636 |
PCB TERMINAL BLOCK 16 MM PIN SPA | |||
| 2636-1101 Wago | 859 ₽ | ||
| 2636-1101/000-016 Wago | по запросу | ||
| Parameters / Models | 2636-1101![]() | 2636-1102/020-000![]() | 2636-1102/020-004![]() | 2636-1103/020-000![]() | 2636-1103/020-004![]() | 2636-1104/020-000![]() | 2636-1105/020-000![]() | 2636-1105/020-004![]() | 2636-1106/020-000![]() | 2636-1107/020-000![]() | 2636-1108/020-000![]() | 2636-1109/020-000![]() | 2636-1110/020-000![]() | 2636-1111/020-000![]() | 2636-1112/020-000![]() | 2636-3101![]() | 2636-3102/020-000![]() | 2636-3103/020-000![]() | 2636-3104/020-000![]() | 2636-3105/020-000![]() | 2636-3106/020-000![]() | 2636-3107/020-000![]() | 2636-3108/020-000![]() | 2636-3109/020-000![]() | 2636-3110/020-000![]() | 2636-3111/020-000![]() | 2636-3112/020-000![]() |
| Actuation type | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool |
| Clamping spring material | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) |
| Цвет | gray | gray | black | gray | black | gray | gray | black | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray |
| Conductor entry angle to the PCB, ° | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | |||||||||||||||
| Connection technology | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® |
| Contact material | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) |
| Contact plating | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated |
| Country of origin | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE |
| Габариты: глубина | 29.1 mm / 1.146 inch | 29.1 mm / 1.146 inch | 29.1 mm / 1.146 inch | 29.1 mm / 1.146 inch | 29.1 mm / 1.146 inch | 29.1 mm / 1.146 inch | 29.1 mm / 1.146 inch | 29.1 mm / 1.146 inch | 29.1 mm / 1.146 inch | 29.1 mm / 1.146 inch | 29.1 mm / 1.146 inch | 29.1 mm / 1.146 inch | 29.1 mm / 1.146 inch | 29.1 mm / 1.146 inch | 29.1 mm / 1.146 inch | 24.8 mm / 0.976 inch | 24.8 mm / 0.976 inch | 24.8 mm / 0.976 inch | 24.8 mm / 0.976 inch | 24.8 mm / 0.976 inch | 24.8 mm / 0.976 inch | 24.8 mm / 0.976 inch | 24.8 mm / 0.976 inch | 24.8 mm / 0.976 inch | 24.8 mm / 0.976 inch | 24.8 mm / 0.976 inch | 24.8 mm / 0.976 inch |
| Drilled hole diameter (tolerance), мм | 1.7(+ 0.1) | 1.7(+ 0.1) | 1.7(+ 0.1) | 1.7(+ 0.1) | 1.7(+ 0.1) | 1.7(+ 0.1) | 1.7(+ 0.1) | 1.7(+ 0.1) | 1.7(+ 0.1) | 1.7(+ 0.1) | 1.7(+ 0.1) | 1.7(+ 0.1) | 1.7(+ 0.1) | 1.7(+ 0.1) | 1.7(+ 0.1) | 1.7(+ 0.1) | 1.7(+ 0.1) | 1.7(+ 0.1) | 1.7(+ 0.1) | 1.7(+ 0.1) | 1.7(+ 0.1) | 1.7(+ 0.1) | 1.7(+ 0.1) | 1.7(+ 0.1) | 1.7(+ 0.1) | 1.7(+ 0.1) | 1.7(+ 0.1) |
| Fine-stranded conductor | 0.75 … 25 mm² / 18 … 4 AWG | 0.75 … 25 mm² / 18 … 4 AWG | 0.75 … 25 mm² / 18 … 4 AWG | 0.75 … 25 mm² / 18 … 4 AWG | 0.75 … 25 mm² / 18 … 4 AWG | 0.75 … 25 mm² / 18 … 4 AWG | 0.75 … 25 mm² / 18 … 4 AWG | 0.75 … 25 mm² / 18 … 4 AWG | 0.75 … 25 mm² / 18 … 4 AWG | 0.75 … 25 mm² / 18 … 4 AWG | 0.75 … 25 mm² / 18 … 4 AWG | 0.75 … 25 mm² / 18 … 4 AWG | 0.75 … 25 mm² / 18 … 4 AWG | 0.75 … 25 mm² / 18 … 4 AWG | 0.75 … 25 mm² / 18 … 4 AWG | 0.75 … 25 mm² / 18 … 4 AWG | 0.75 … 25 mm² / 18 … 4 AWG | 0.75 … 25 mm² / 18 … 4 AWG | 0.75 … 25 mm² / 18 … 4 AWG | 0.75 … 25 mm² / 18 … 4 AWG | 0.75 … 25 mm² / 18 … 4 AWG | 0.75 … 25 mm² / 18 … 4 AWG | 0.75 … 25 mm² / 18 … 4 AWG | 0.75 … 25 mm² / 18 … 4 AWG | 0.75 … 25 mm² / 18 … 4 AWG | 0.75 … 25 mm² / 18 … 4 AWG | 0.75 … 25 mm² / 18 … 4 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² | 0.75 … 16 mm² |
| Fine-stranded conductor, with twin ferrule | 0.75 … 6 mm² | 0.75 … 6 mm² | 0.75 … 6 mm² | 0.75 … 6 mm² | 0.75 … 6 mm² | 0.75 … 6 mm² | 0.75 … 6 mm² | 0.75 … 6 mm² | 0.75 … 6 mm² | 0.75 … 6 mm² | 0.75 … 6 mm² | 0.75 … 6 mm² | 0.75 … 6 mm² | 0.75 … 6 mm² | 0.75 … 6 mm² | 0.75 … 6 mm² | 0.75 … 6 mm² | 0.75 … 6 mm² | 0.75 … 6 mm² | 0.75 … 6 mm² | 0.75 … 6 mm² | 0.75 … 6 mm² | 0.75 … 6 mm² | 0.75 … 6 mm² | 0.75 … 6 mm² | 0.75 … 6 mm² | 0.75 … 6 mm² |
| Flammability class per UL94 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 |
| GTIN | 4055143625234 | 4055143625289 | 4055143766005 | 4055143625319 | 4055143765992 | 4055143625326 | 4055143625340 | 4055143765985 | 4055143625357 | 4055143625371 | 4055143625388 | 4055143625401 | 4055143625418 | 4055143625425 | 4055143625432 | 4055143625470 | 4055143625517 | 4055143625548 | 4055143625555 | 4055143625579 | 4055143625586 | 4055143625593 | 4055143625609 | 4055143625616 | 4055143625623 | 4055143625630 | 4055143625647 |
| Height | 32.6 mm / 1.283 inch | 32.6 mm / 1.283 inch | 32.6 mm / 1.283 inch | 32.6 mm / 1.283 inch | 32.6 mm / 1.283 inch | 32.6 mm / 1.283 inch | 32.6 mm / 1.283 inch | 32.6 mm / 1.283 inch | 32.6 mm / 1.283 inch | 32.6 mm / 1.283 inch | 32.6 mm / 1.283 inch | 32.6 mm / 1.283 inch | 32.6 mm / 1.283 inch | 32.6 mm / 1.283 inch | 32.6 mm / 1.283 inch | 35.3 mm / 1.39 inch | 35.3 mm / 1.39 inch | 35.3 mm / 1.39 inch | 35.3 mm / 1.39 inch | 35.3 mm / 1.39 inch | 35.3 mm / 1.39 inch | 35.3 mm / 1.39 inch | 35.3 mm / 1.39 inch | 35.3 mm / 1.39 inch | 35.3 mm / 1.39 inch | 35.3 mm / 1.39 inch | 35.3 mm / 1.39 inch |
| Height from the surface | 28.6 mm / 1.126 inch | 28.6 mm / 1.126 inch | 28.6 mm / 1.126 inch | 28.6 mm / 1.126 inch | 28.6 mm / 1.126 inch | 28.6 mm / 1.126 inch | 28.6 mm / 1.126 inch | 28.6 mm / 1.126 inch | 28.6 mm / 1.126 inch | 28.6 mm / 1.126 inch | 28.6 mm / 1.126 inch | 28.6 mm / 1.126 inch | 28.6 mm / 1.126 inch | 28.6 mm / 1.126 inch | 28.6 mm / 1.126 inch | 31.3 mm / 1.232 inch | 31.3 mm / 1.232 inch | 31.3 mm / 1.232 inch | 31.3 mm / 1.232 inch | 31.3 mm / 1.232 inch | 31.3 mm / 1.232 inch | 31.3 mm / 1.232 inch | 31.3 mm / 1.232 inch | 31.3 mm / 1.232 inch | 31.3 mm / 1.232 inch | 31.3 mm / 1.232 inch | 31.3 mm / 1.232 inch |
| Insulating material | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) |
| Legend (ratings) | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 |
| Limit temperature range | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C |
| Material group | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I |
| Number of Poles | 1 | 2 | 2 | 3 | 3 | 4 | 5 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 |
| Number of connection types | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| Number of levels | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| Number of solder pins per potential | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
| PCB contact | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT |
| Packaging type | BOX | BOX | BOX | ||||||||||||||||||||||||
| Pin spacing | 10 mm (0.394 inch) | 10 mm (0.394 inch) | 10 mm (0.394 inch) | 10 mm (0.394 inch) | 10 mm (0.394 inch) | 10 mm (0.394 inch) | 10 mm (0.394 inch) | 10 mm (0.394 inch) | 10 mm (0.394 inch) | 10 mm (0.394 inch) | 10 mm (0.394 inch) | 10 mm (0.394 inch) | 10 mm (0.394 inch) | 10 mm (0.394 inch) | 10 mm (0.394 inch) | 10 mm (0.394 inch) | 10 mm (0.394 inch) | 10 mm (0.394 inch) | 10 mm (0.394 inch) | 10 mm (0.394 inch) | 10 mm (0.394 inch) | 10 mm (0.394 inch) | 10 mm (0.394 inch) | 10 mm (0.394 inch) | 10 mm (0.394 inch) | 10 mm (0.394 inch) | 10 mm (0.394 inch) |
| Rated current, A | 76 | 76 | 76 | 76 | 76 | 76 | 76 | 76 | 76 | 76 | 76 | 76 | 76 | 76 | 76 | 76 | 76 | 76 | 76 | 76 | 76 | 76 | 76 | 76 | 76 | 76 | 76 |
| Rated impulse voltage (II / 2), kV | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
| Rated impulse voltage (III / 2), kV | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
| Rated impulse voltage (III / 3), kV | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
| Rated voltage (II / 2), В | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 |
| Rated voltage (III / 2), В | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 |
| Rated voltage (III / 3), В | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 |
| Solder pin arrangement | within the terminal block, in line | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | within the terminal block, in line | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered |
| Solder pin dimensions | 1.2 x 1 mm | 1.2 x 1 mm | 1.2 x 1 mm | 1.2 x 1 mm | 1.2 x 1 mm | 1.2 x 1 mm | 1.2 x 1 mm | 1.2 x 1 mm | 1.2 x 1 mm | 1.2 x 1 mm | 1.2 x 1 mm | 1.2 x 1 mm | 1.2 x 1 mm | 1.2 x 1 mm | 1.2 x 1 mm | 1.2 x 1 mm | 1.2 x 1 mm | 1.2 x 1 mm | 1.2 x 1 mm | 1.2 x 1 mm | 1.2 x 1 mm | 1.2 x 1 mm | 1.2 x 1 mm | 1.2 x 1 mm | 1.2 x 1 mm | 1.2 x 1 mm | 1.2 x 1 mm |
| Solder pin length, мм | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
| Solid conductor | 0.75 … 16 mm² / 18 … 4 AWG | 0.75 … 16 mm² / 18 … 4 AWG | 0.75 … 16 mm² / 18 … 4 AWG | 0.75 … 16 mm² / 18 … 4 AWG | 0.75 … 16 mm² / 18 … 4 AWG | 0.75 … 16 mm² / 18 … 4 AWG | 0.75 … 16 mm² / 18 … 4 AWG | 0.75 … 16 mm² / 18 … 4 AWG | 0.75 … 16 mm² / 18 … 4 AWG | 0.75 … 16 mm² / 18 … 4 AWG | 0.75 … 16 mm² / 18 … 4 AWG | 0.75 … 16 mm² / 18 … 4 AWG | 0.75 … 16 mm² / 18 … 4 AWG | 0.75 … 16 mm² / 18 … 4 AWG | 0.75 … 16 mm² / 18 … 4 AWG | 0.75 … 16 mm² / 18 … 4 AWG | 0.75 … 16 mm² / 18 … 4 AWG | 0.75 … 16 mm² / 18 … 4 AWG | 0.75 … 16 mm² / 18 … 4 AWG | 0.75 … 16 mm² / 18 … 4 AWG | 0.75 … 16 mm² / 18 … 4 AWG | 0.75 … 16 mm² / 18 … 4 AWG | 0.75 … 16 mm² / 18 … 4 AWG | 0.75 … 16 mm² / 18 … 4 AWG | 0.75 … 16 mm² / 18 … 4 AWG | 0.75 … 16 mm² / 18 … 4 AWG | 0.75 … 16 mm² / 18 … 4 AWG |
| Strip length | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch | 18 … 20 mm / 0.71 … 0.79 Inch |
| Total number of connection points | 1 | 2 | 2 | 3 | 3 | 4 | 5 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 |
| Total number of potentials | 1 | 2 | 2 | 3 | 3 | 4 | 5 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 |
| Type of mounting | Feed-through mounting | Feed-through mounting | Feed-through mounting | Feed-through mounting | Feed-through mounting | Feed-through mounting | Feed-through mounting | Feed-through mounting | Feed-through mounting | Feed-through mounting | Feed-through mounting | Feed-through mounting | Feed-through mounting | Feed-through mounting | Feed-through mounting | Feed-through mounting | Feed-through mounting | Feed-through mounting | Feed-through mounting | Feed-through mounting | Feed-through mounting | Feed-through mounting | Feed-through mounting | Feed-through mounting | Feed-through mounting | Feed-through mounting | Feed-through mounting |
| Вес, г | 9.764 | 17.398 | 16.988 | 25.582 | 25.582 | 33.746 | 41.93 | 41.93 | 50.094 | 58.278 | 66.442 | 74.626 | 82.79 | 90.974 | 99.138 | 9.284 | 16.818 | 24.812 | 32.656 | 40.65 | 48.494 | 56.488 | 64.332 | 72.326 | 80.17 | 88.164 | 96.008 |
| Ширина | 11.6 mm / 0.457 inch | 21.6 mm / 0.85 inch | 21.6 mm / 0.85 inch | 31.6 mm / 1.244 inch | 31.6 mm / 1.244 inch | 41.6 mm / 1.638 inch | 51.6 mm / 2.031 inch | 51.6 mm / 2.031 inch | 61.6 mm / 2.425 inch | 71.6 mm / 2.819 inch | 81.6 mm / 3.213 inch | 91.6 mm / 3.606 inch | 101.6 mm / 4 inch | 111.6 mm / 4.394 inch | 121.6 mm / 4.787 inch | 11.6 mm / 0.457 inch | 21.6 mm / 0.85 inch | 31.6 mm / 1.244 inch | 41.6 mm / 1.638 inch | 51.6 mm / 2.031 inch | 61.6 mm / 2.425 inch | 71.6 mm / 2.819 inch | 81.6 mm / 3.213 inch | 91.6 mm / 3.606 inch | 101.6 mm / 4 inch | 111.6 mm / 4.394 inch | 121.6 mm / 4.787 inch |
Серия: 2636 (27)
- 2636-1101 2636-1102/020-000 2636-1102/020-004 2636-1103/020-000 2636-1103/020-004 2636-1104/020-000 2636-1105/020-000 2636-1105/020-004 2636-1106/020-000 2636-1107/020-000 2636-1108/020-000 2636-1109/020-000 2636-1110/020-000 2636-1111/020-000 2636-1112/020-000 2636-3101 2636-3102/020-000 2636-3103/020-000 2636-3104/020-000 2636-3105/020-000 2636-3106/020-000 2636-3107/020-000 2636-3108/020-000 2636-3109/020-000 2636-3110/020-000 2636-3111/020-000 2636-3112/020-000
- PCB Interconnect
