Источники питания Keen Side
Datasheet Wago 2636-1103/020-004 — Даташит
Серия2636
Модель2636-1103/020-004
Клеммная колодка для печатной платы; 16 мм²; Шаг контактов 10 мм; 3-полюсный; Push-in CAGE CLAMP; специальная версия
2636-1103/020-004
Actuation typeOperating tool
Цветblack
Contact platingtin-plated
Country of originDE
Габариты: глубина29.1 mm / 1.146 inch
Drilled hole diameter (tolerance)1.7(+ 0.1) мм
Fine-stranded conductor0.75 … 25 mm² / 18 … 4 AWG
Fine-stranded conductor with ferrule with plastic collar0.75 … 16 mm²
Fine-stranded conductor with ferrule without plastic collar0.75 … 16 mm²
Fine-stranded conductor, with twin ferrule0.75 … 6 mm²
GTIN4055143765992
Height32.6 mm / 1.283 inch
Height from the surface28.6 mm / 1.126 inch
Material groupI
Number of Poles3
Number of connection types1
Number of levels1
Number of solder pins per potential3
PCB contactTHT
Packaging typeBOX
Pin spacing10 mm (0.394 inch)
Rated current76 A
Rated impulse voltage (II / 2)8 kV
Rated impulse voltage (III / 2)8 kV
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)1000 В
Rated voltage (III / 3)1000 В
Solder pin arrangementover the entire terminal strip, staggered
Solder pin dimensions1.2 x 1 mm
Solder pin length4 мм
Solid conductor0.75 … 16 mm² / 18 … 4 AWG
Strip length18 … 20 mm / 0.71 … 0.79 Inch
Total number of connection points3
Total number of potentials3
Type of mountingFeed-through mounting
Вес25.582 г
Ширина31.6 mm / 1.244 inch
  • PCB Interconnect
26361103/020004, 2636 1103/020 004
На английском языке: Datasheet Wago 2636-1103/020-004
