Datasheet Wago 2636-1110/020-000 — Даташит
Клеммная колодка для печатной платы; 16 мм²; Шаг контактов 10 мм; 10-полюсный; Зажим Push-in CAGE CLAMP
PCB TERMINAL BLOCK; 16 MM; PIN S | |||
2636-1110/020-000 Wago | 1 615 ₽ | ||
2636-1110/020-000 Wago | по запросу |
Цвет | gray |
Country of origin | DE |
Габариты: глубина | 29.1 mm / 1.146 inch |
Drilled hole diameter (tolerance) | 1.7(+ 0.1) мм |
Fine-stranded conductor | 0.75 … 25 mm² / 18 … 4 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.75 … 16 mm² |
Fine-stranded conductor with ferrule without plastic collar | 0.75 … 16 mm² |
Fine-stranded conductor, with twin ferrule | 0.75 … 6 mm² |
GTIN | 4055143625418 |
Height | 32.6 mm / 1.283 inch |
Height from the surface | 28.6 mm / 1.126 inch |
Material group | I |
Number of Poles | 10 |
Number of levels | 1 |
Number of solder pins per potential | 3 |
PCB contact | THT |
Pin spacing | 10 mm (0.394 inch) |
Rated current | 76 A |
Rated impulse voltage (II / 2) | 8 kV |
Rated impulse voltage (III / 2) | 8 kV |
Rated impulse voltage (III / 3) | 8 kV |
Rated voltage (III / 2) | 1000 В |
Rated voltage (III / 3) | 1000 В |
Solder pin arrangement | over the entire terminal strip, staggered |
Solder pin dimensions | 1.2 x 1 mm |
Solder pin length | 4 мм |
Solid conductor | 0.75 … 16 mm² / 18 … 4 AWG |
Strip length | 18 … 20 mm / 0.71 … 0.79 Inch |
Total number of connection points | 10 |
Total number of potentials | 10 |
Type of mounting | Feed-through mounting |
Вес | 82.79 г |
Ширина | 101.6 mm / 4 inch |
Серия: 2636 (27)
- 2636-1101 2636-1102/020-000 2636-1102/020-004 2636-1103/020-000 2636-1103/020-004 2636-1104/020-000 2636-1105/020-000 2636-1105/020-004 2636-1106/020-000 2636-1107/020-000 2636-1108/020-000 2636-1109/020-000 2636-1110/020-000 2636-1111/020-000 2636-1112/020-000 2636-3101 2636-3102/020-000 2636-3103/020-000 2636-3104/020-000 2636-3105/020-000 2636-3106/020-000 2636-3107/020-000 2636-3108/020-000 2636-3109/020-000 2636-3110/020-000 2636-3111/020-000 2636-3112/020-000
- PCB Interconnect
26361110/020000, 2636 1110/020 000
