Линейка продуктов KEEN SIDE
Datasheet Wago 2636-1111/020-000 — Даташит
Серия2636
Модель2636-1111/020-000
Клеммная колодка для печатной платы; 16 мм²; Шаг контактов 10 мм; 11-полюсный; Зажим Push-in CAGE CLAMP
2636-1111/020-000
Actuation typeOperating tool
Цветgray
Contact platingtin-plated
Country of originDE
Габариты: глубина29.1 mm / 1.146 inch
Drilled hole diameter (tolerance)1.7(+ 0.1) мм
Fine-stranded conductor0.75 … 25 mm² / 18 … 4 AWG
Fine-stranded conductor with ferrule with plastic collar0.75 … 16 mm²
Fine-stranded conductor with ferrule without plastic collar0.75 … 16 mm²
Fine-stranded conductor, with twin ferrule0.75 … 6 mm²
GTIN4055143625425
Height32.6 mm / 1.283 inch
Height from the surface28.6 mm / 1.126 inch
Material groupI
Number of Poles11
Number of connection types1
Number of levels1
Number of solder pins per potential3
PCB contactTHT
Pin spacing10 mm (0.394 inch)
Rated current76 A
Rated impulse voltage (II / 2)8 kV
Rated impulse voltage (III / 2)8 kV
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)1000 В
Rated voltage (III / 3)1000 В
Solder pin arrangementover the entire terminal strip, staggered
Solder pin dimensions1.2 x 1 mm
Solder pin length4 мм
Solid conductor0.75 … 16 mm² / 18 … 4 AWG
Strip length18 … 20 mm / 0.71 … 0.79 Inch
Total number of connection points11
Total number of potentials11
Type of mountingFeed-through mounting
Вес90.974 г
Ширина111.6 mm / 4.394 inch
  • PCB Interconnect
26361111/020000, 2636 1111/020 000
На английском языке: Datasheet Wago 2636-1111/020-000
