Datasheet Wago 2636-3107/020-000 — Даташит
Клеммная колодка для печатной платы; 16 мм²; Шаг контактов 10 мм; 7-полюсный; Зажим Push-in CAGE CLAMP
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Conductor entry angle to the PCB | 90 ° |
| Connection technology | Push-in CAGE CLAMP® |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | DE |
| Габариты: глубина | 24.8 mm / 0.976 inch |
| Drilled hole diameter (tolerance) | 1.7(+ 0.1) мм |
| Fine-stranded conductor | 0.75 … 25 mm² / 18 … 4 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.75 … 16 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.75 … 16 mm² |
| Fine-stranded conductor, with twin ferrule | 0.75 … 6 mm² |
| GTIN | 4055143625593 |
| Height | 35.3 mm / 1.39 inch |
| Height from the surface | 31.3 mm / 1.232 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 7 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 3 |
| PCB contact | THT |
| Pin spacing | 10 mm (0.394 inch) |
| Rated current | 76 A |
| Rated impulse voltage (II / 2) | 8 kV |
| Rated impulse voltage (III / 2) | 8 kV |
| Rated impulse voltage (III / 3) | 8 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 1000 В |
| Rated voltage (III / 3) | 1000 В |
| Solder pin arrangement | over the entire terminal strip, staggered |
| Solder pin dimensions | 1.2 x 1 mm |
| Solder pin length | 4 мм |
| Solid conductor | 0.75 … 16 mm² / 18 … 4 AWG |
| Strip length | 18 … 20 mm / 0.71 … 0.79 Inch |
| Total number of connection points | 7 |
| Total number of potentials | 7 |
| Type of mounting | Feed-through mounting |
| Вес | 56.488 г |
| Ширина | 71.6 mm / 2.819 inch |
Серия: 2636 (27)
- 2636-1101 2636-1102/020-000 2636-1102/020-004 2636-1103/020-000 2636-1103/020-004 2636-1104/020-000 2636-1105/020-000 2636-1105/020-004 2636-1106/020-000 2636-1107/020-000 2636-1108/020-000 2636-1109/020-000 2636-1110/020-000 2636-1111/020-000 2636-1112/020-000 2636-3101 2636-3102/020-000 2636-3103/020-000 2636-3104/020-000 2636-3105/020-000 2636-3106/020-000 2636-3107/020-000 2636-3108/020-000 2636-3109/020-000 2636-3110/020-000 2636-3111/020-000 2636-3112/020-000
- PCB Interconnect
26363107/020000, 2636 3107/020 000
