Datasheet Wago 2706-103/000-004 — Даташит
Клеммная колодка для печатной платы; рычаг; 6 мм²; Шаг контактов 7,5 мм; 3-полюсный; CAGE CLAMP
Купить 2706-103 на РадиоЛоцман.Цены — от 505 до 933 ₽14 предложений от 4 поставщиков PCB TERMINAL BLOCK; LEVER; 6 MM; | |||
| 2706-103 Wago | 505 ₽ | ||
| 2706-103 | от 751 ₽ | ||
| 2706-103 Wago | от 933 ₽ | ||
| 2706-103 Wago | по запросу | ||
| Actuation type | Lever |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | black |
| Conductor entry angle to the PCB | 30 ° |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | PL |
| Габариты: глубина | 26 mm / 1.024 inch |
| Drilled hole diameter (tolerance) | 1.8(+ 0.1) мм |
| Fine-stranded conductor | 0.5 … 6 mm² / 20 … 10 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.5 … 6 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.5 … 6 mm² |
| Fire load | 0.283 MJ |
| GTIN | 4050821250418 |
| Height | 30 mm / 1.181 inch |
| Height from the surface | 25.5 mm / 1.004 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 3 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 7.5 mm (0.295 inch) |
| Product Group | 4 (Printed Circuit) |
| Rated current | 41 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 500 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solder pin dimensions | 1 x 1.4 mm |
| Solder pin length | 4.5 мм |
| Solid conductor | 0.5 … 6 mm² / 20 … 10 AWG |
| Strip length | 11 … 12 mm / 0.43 … 0.47 Inch |
| Total number of connection points | 3 |
| Total number of potentials | 3 |
| Вес | 15.549 г |
| Ширина | 22.5 mm / 0.886 inch |
Серия: 2706 (90)
- 2706-102 2706-102/000-004 2706-102/000-009 2706-102/000-015 2706-102/000-016 2706-102/000-017 2706-103 2706-103/000-004 2706-104 2706-104/000-004 2706-104/000-009 2706-104/000-015 2706-105 2706-105/000-004 2706-105/000-015 2706-106 2706-106/000-004 2706-106/000-009 2706-107 2706-107/000-004 2706-108 2706-108/000-009 2706-109 2706-109/000-004 2706-110 2706-110/000-004 2706-111 2706-111/000-004 2706-112 2706-112/000-004 2706-152 2706-153 2706-154 2706-155 2706-155/000-016 2706-156 2706-157 2706-158 2706-159 2706-160 2706-161 2706-162 2706-202 2706-202/000-004 2706-203 2706-203/000-004 2706-204 2706-204/000-004 2706-204/000-009 2706-205 2706-205/000-004 2706-206 2706-206/000-004 2706-206/000-009 2706-207 2706-207/000-004 2706-208 2706-208/000-004 2706-209 2706-209/000-004 2706-210 2706-210/000-004 2706-211 2706-211/000-004 2706-211/000-016 2706-212 2706-212/000-004 2706-252 2706-253 2706-254 2706-255 2706-256 2706-257 2706-258 2706-259 2706-260 2706-261 2706-262 2706-302 2706-303 2706-304 2706-304/000-009 2706-305 2706-306 2706-307 2706-308 2706-309 2706-310 2706-311 2706-312
- PCB Interconnect
2706103/000004, 2706 103/000 004
