Datasheet Wago 2706-161 — Даташит
Серия2706
Модель2706-161
Клеммная колодка для печатной платы; рычаг; 6 мм²; Шаг контактов 7,5 мм; 11-полюсный; CAGE CLAMP; возможность объединения
Actuation typeLever
Цветgray
Conductor entry angle to the PCB30 °
Contact platingtin-plated
Country of originPL
Габариты: глубина30 mm / 1.181 inch
Drilled hole diameter (tolerance)1.8(+ 0.1) мм
Fine-stranded conductor0.5 … 6 mm² / 20 … 10 AWG
Fine-stranded conductor with ferrule with plastic collar0.5 … 6 mm²
Fine-stranded conductor with ferrule without plastic collar0.5 … 6 mm²
Fire load1.187 MJ
GTIN4050821093206
Height30 mm / 1.181 inch
Height from the surface25.5 mm / 1.004 inch
Material groupI
Number of Poles11
Number of connection types1
Number of jumper slots1
Number of levels1
PCB contactTHT
Pin spacing7.5 mm (0.295 inch)
Rated current41 A
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)630 В
Rated voltage (III / 3)500 В
Ratings noteUsing adjacent jumpers, the rated voltage is reduced to 400 V with 7.5 mm pin spacing in Category III/3
Solder pin dimensions1 x 1.4 mm
Solder pin length4.5 мм
Solid conductor0.5 … 6 mm² / 20 … 10 AWG
Strip length11 … 12 mm / 0.43 … 0.47 Inch
Total number of connection points11
Total number of potentials11
Вес63.258 г
Ширина82.5 mm / 3.248 inch
  • PCB Interconnect
2706161, 2706 161
На английском языке: Datasheet Wago 2706-161
