Datasheet Wago 2706-205/000-004 — Даташит
Серия2706
Модель2706-205/000-004
Клеммная колодка для печатной платы; рычаг; 6 мм²; Шаг контактов 10 мм; 5-полюсный; CAGE CLAMP
586-2706-205
Actuation typeLever
Цветblack
Conductor entry angle to the PCB30 °
Contact platingtin-plated
Country of originPL
Габариты: глубина26 mm / 1.024 inch
Drilled hole diameter (tolerance)1.8(+ 0.1) мм
Fine-stranded conductor0.5 … 6 mm² / 20 … 10 AWG
Fine-stranded conductor with ferrule with plastic collar0.5 … 6 mm²
Fine-stranded conductor with ferrule without plastic collar0.5 … 6 mm²
Fire load0.585 MJ
GTIN4050821251255
Height30 mm / 1.181 inch
Height from the surface25.5 mm / 1.004 inch
Material groupI
Number of Poles5
Number of connection types1
Number of levels1
PCB contactTHT
Pin spacing10 mm (0.394 inch)
Rated current41 A
Rated impulse voltage (II / 2)8 kV
Rated impulse voltage (III / 2)8 kV
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)1000 В
Rated voltage (III / 3)800 В
Solder pin dimensions1 x 1.4 mm
Solder pin length4.5 мм
Solid conductor0.5 … 6 mm² / 20 … 10 AWG
Strip length11 … 12 mm / 0.43 … 0.47 Inch
Total number of connection points5
Total number of potentials5
Вес29.733 г
Ширина45 mm / 1.772 inch
  • PCB Interconnect
2706205/000004, 2706 205/000 004
На английском языке: Datasheet Wago 2706-205/000-004
