Datasheet Wago 2716 — Даташит
Серия2716
Datasheet Wago 2716
25 предложений от 7 поставщиков
Клеммная колодка типа провод к плате, 10 мм, 2 вывод(-ов), 16 AWG, 6 AWG, 16 мм², Вставной
Элитан
765 ₽
Эиком
от 1 019 ₽
2716-102
от 1 073 ₽
Parameters / Models2716-102
2716-102
2716-103
2716-103
2716-104
2716-104
2716-105
2716-105
2716-106
2716-106
2716-107
2716-107
2716-108
2716-108
2716-152
2716-152
2716-153
2716-153
2716-154
2716-154
2716-155
2716-155
2716-156
2716-156
2716-157
2716-157
2716-158
2716-158
2716-202
2716-202
2716-203
2716-203
2716-203/000-005
2716-203/000-005
2716-204
2716-204
2716-205
2716-205
2716-206
2716-206
2716-207
2716-207
2716-208
2716-208
2716-252
2716-252
2716-253
2716-253
2716-254
2716-254
2716-255
2716-255
2716-256
2716-256
2716-257
2716-257
2716-258
2716-258
Actuation typeLeverLeverLeverLeverLeverLeverLeverLeverLeverLeverLeverLeverLeverLeverLeverLeverLeverLeverLeverLeverLeverLeverLeverLeverLeverLeverLeverLeverLever
Clamping spring materialChrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)
Цветgraygraygraygraygraygraygraygraygraygraygraygraygraygraygraygrayredgraygraygraygraygraygraygraygraygraygraygraygray
Conductor entry angle to the PCB, °3030303030303030303030303030303030303030303030303030303030
Connection technologyCAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®
Contact materialElectrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)
Contact platingtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-plated
Country of originPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPL
Габариты: глубина30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch35 mm / 1.378 inch35 mm / 1.378 inch35 mm / 1.378 inch35 mm / 1.378 inch35 mm / 1.378 inch35 mm / 1.378 inch35 mm / 1.378 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch35 mm / 1.378 inch35 mm / 1.378 inch35 mm / 1.378 inch35 mm / 1.378 inch35 mm / 1.378 inch35 mm / 1.378 inch35 mm / 1.378 inch
Drilled hole diameter (tolerance), мм1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)1.6(+ 0.1)
Fine-stranded conductor1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG
Fine-stranded conductor with ferrule with plastic collar1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²
Fine-stranded conductor with ferrule without plastic collar1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²1.5 … 10 mm²
Fire load, MJ0.3010.4520.6030.7540.9051.0561.2070.3540.5320.710.8881.0661.2441.4220.3650.580.580.7951.011.2251.441.6550.4310.6860.9411.1961.4511.7061.961
Flammability class per UL94V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0
GTIN40454547391404045454739270404545473928740454547392944045454739300404545473931740454547393244045454739331404545473934840454547393554045454739379404545473938640454547393934045454739409404545473941640454547394234050821517818404545473943040454547394474045454739454404545473946140454547394784045454739485404545473949240454547395084045454739515404545473952240454547395394045454739546
Height33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch33.3 mm / 1.311 inch
Height from the surface28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch28.8 mm / 1.134 inch
Insulating materialPolyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)
Legend (ratings)(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2
Limit temperature range-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C
Material groupIIIIIIIIIIIIIIIIIIIIIIIIIIIII
Number of Poles23456782345678233456782345678
Number of connection types11111111111111111111111111111
Number of jumper slots11111111111111
Number of levels11111111111111111111111111111
Number of solder pins per potential44444444444444444444444444444
PCB contactTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHT
Pin spacing10 mm (0.394 inch)10 mm (0.394 inch)10 mm (0.394 inch)10 mm (0.394 inch)10 mm (0.394 inch)10 mm (0.394 inch)10 mm (0.394 inch)10 mm (0.394 inch)10 mm (0.394 inch)10 mm (0.394 inch)10 mm (0.394 inch)10 mm (0.394 inch)10 mm (0.394 inch)10 mm (0.394 inch)15 mm (0.591 inch)15 mm (0.591 inch)15 mm (0.591 inch)15 mm (0.591 inch)15 mm (0.591 inch)15 mm (0.591 inch)15 mm (0.591 inch)15 mm (0.591 inch)15 mm (0.591 inch)15 mm (0.591 inch)15 mm (0.591 inch)15 mm (0.591 inch)15 mm (0.591 inch)15 mm (0.591 inch)15 mm (0.591 inch)
Product Group4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)
Rated current, A7676767676767676767676767676767676767676767676767676767676
Rated impulse voltage (II / 2), kV44444444444444888888888888888
Rated impulse voltage (III / 2), kV44444444444444888888888888888
Rated impulse voltage (III / 3), kV44444444444444888888888888888
Rated voltage (II / 2), В630630630630630630630630630630630630630630100010001000100010001000100010001000100010001000100010001000
Rated voltage (III / 2), В320320320320320320320320320320320320320320100010001000100010001000100010001000100010001000100010001000
Rated voltage (III / 3), В320320320320320320320320320320320320320320800800800800800800800800800800800800800800800
Solder pin arrangementover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in lineover the entire terminal strip, in line
Solder pin dimensions0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm0.95 x 1.2 mm
Solder pin length, мм4.54.54.54.54.54.54.54.54.54.54.54.54.54.54.54.54.54.54.54.54.54.54.54.54.54.54.54.54.5
Solid conductor1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG1.5 … 16 mm² / 16 … 6 AWG
Strip length12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch12 … 13 mm / 0.47 … 0.51 Inch
Total number of connection points2345678234567823456782345678
Total number of potentials23456782345678233456782345678
Вес, г17.83426.77135.70844.64553.58262.51971.45620.91531.40341.89152.37962.86773.35583.84319.9631.02331.02342.08653.14964.21275.27586.33823.46736.50749.54762.58775.62788.667101.707
Ширина21.5 mm / 0.846 inch31.5 mm / 1.24 inch41.5 mm / 1.634 inch51.5 mm / 2.028 inch61.5 mm / 2.421 inch71.5 mm / 2.815 inch81.5 mm / 3.209 inch21.5 mm / 0.846 inch31.5 mm / 1.24 inch41.5 mm / 1.634 inch51.5 mm / 2.028 inch61.5 mm / 2.421 inch71.5 mm / 2.815 inch81.5 mm / 3.209 inch26.5 mm / 1.043 inch41.5 mm / 1.634 inch41.5 mm / 1.634 inch56.5 mm / 2.224 inch71.5 mm / 2.815 inch86.5 mm / 3.406 inch101.5 mm / 3.996 inch116.5 mm / 4.587 inch26.5 mm / 1.043 inch41.5 mm / 1.634 inch56.5 mm / 2.224 inch71.5 mm / 2.815 inch86.5 mm / 3.406 inch101.5 mm / 3.996 inch116.5 mm / 4.587 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 2716
