Datasheet Wago 2716-204 — Даташит
Клеммная колодка для печатной платы; рычаг; 16 мм²; Шаг контактов 15 мм; 4-полюсный; CAGE CLAMP
![]() 16 предложений от 6 поставщиков Клеммные Колодки типа Провод-плата | |||
2716-204 Wago | 798 ₽ | ||
2716-204 | от 1 612 ₽ | ||
2716-204 Wago | 2 695 ₽ | ||
2716-204 Wago | по запросу |
Actuation type | Lever |
Цвет | gray |
Conductor entry angle to the PCB | 30 ° |
Country of origin | PL |
Габариты: глубина | 30 mm / 1.181 inch |
Drilled hole diameter (tolerance) | 1.6(+ 0.1) мм |
Fine-stranded conductor | 1.5 … 16 mm² / 16 … 6 AWG |
Fine-stranded conductor with ferrule with plastic collar | 1.5 … 10 mm² |
Fine-stranded conductor with ferrule without plastic collar | 1.5 … 10 mm² |
Fire load | 0.795 MJ |
GTIN | 4045454739430 |
Height | 33.3 mm / 1.311 inch |
Height from the surface | 28.8 mm / 1.134 inch |
Material group | I |
Number of Poles | 4 |
Number of levels | 1 |
Number of solder pins per potential | 4 |
PCB contact | THT |
Pin spacing | 15 mm (0.591 inch) |
Rated current | 76 A |
Rated impulse voltage (II / 2) | 8 kV |
Rated impulse voltage (III / 2) | 8 kV |
Rated impulse voltage (III / 3) | 8 kV |
Rated voltage (III / 2) | 1000 В |
Rated voltage (III / 3) | 800 В |
Solder pin arrangement | over the entire terminal strip, in line |
Solder pin dimensions | 0.95 x 1.2 mm |
Solder pin length | 4.5 мм |
Solid conductor | 1.5 … 16 mm² / 16 … 6 AWG |
Strip length | 12 … 13 mm / 0.47 … 0.51 Inch |
Total number of connection points | 4 |
Total number of potentials | 4 |
Вес | 42.086 г |
Ширина | 56.5 mm / 2.224 inch |
Серия: 2716 (29)
- PCB Interconnect
2716204, 2716 204
