Datasheet Wago 2716-205 — Даташит
Серия2716
Модель2716-205
Клеммная колодка для печатной платы; рычаг; 16 мм²; Шаг контактов 15 мм; 5-полюсный; CAGE CLAMP
827 ₽
Actuation typeLever
Цветgray
Conductor entry angle to the PCB30 °
Contact platingtin-plated
Country of originPL
Габариты: глубина30 mm / 1.181 inch
Drilled hole diameter (tolerance)1.6(+ 0.1) мм
Fine-stranded conductor1.5 … 16 mm² / 16 … 6 AWG
Fine-stranded conductor with ferrule with plastic collar1.5 … 10 mm²
Fine-stranded conductor with ferrule without plastic collar1.5 … 10 mm²
Fire load1.01 MJ
GTIN4045454739447
Height33.3 mm / 1.311 inch
Height from the surface28.8 mm / 1.134 inch
Material groupI
Number of Poles5
Number of connection types1
Number of levels1
Number of solder pins per potential4
PCB contactTHT
Pin spacing15 mm (0.591 inch)
Rated current76 A
Rated impulse voltage (II / 2)8 kV
Rated impulse voltage (III / 2)8 kV
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)1000 В
Rated voltage (III / 3)800 В
Solder pin dimensions0.95 x 1.2 mm
Solder pin length4.5 мм
Solid conductor1.5 … 16 mm² / 16 … 6 AWG
Strip length12 … 13 mm / 0.47 … 0.51 Inch
Total number of connection points5
Total number of potentials5
Вес53.149 г
Ширина71.5 mm / 2.815 inch
  • PCB Interconnect
2716205, 2716 205
На английском языке: Datasheet Wago 2716-205
