Datasheet Wago 2721-210/008-000 — Даташит
1-проводниковая розетка; 100% защита от неправильного подсоединения; Нажимная кнопка; Монтажные ножки; 2,5 мм²; Шаг контактов 7,5 мм; 10-пол.
1-CONDUCTOR FEMALE PLUG; 100% PR | |||
| 2721-210/008-000 Wago | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light gray |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | PL |
| Габариты: глубина | 25.6 mm / 1.008 inch |
| Fine-stranded conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.446 MJ |
| GTIN | 4045454745158 |
| Gehäuseblechstärke | 0.6 … 1.2 mm / 0.024 … 0.047 inch |
| Height | 19.5 mm / 0.768 inch |
| Height from the surface | 15 mm / 0.591 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | Yes |
| Mounting type | Snap-in mounting foot |
| Number of Poles | 10 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 7.5 mm (0.295 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 500 В |
| Solid conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Strip length | 10 … 11 mm / 0.39 … 0.43 Inch |
| Total number of connection points | 10 |
| Total number of potentials | 10 |
| Type of mounting | Panel mounting |
| Вес | 19.92 г |
| Ширина | 74 mm / 2.913 inch |
Серия: 2721 (100 из 106)
- 2721-103/026-000/133-000 2721-103/031-000 2721-103/037-000 2721-104/008-000 2721-104/026-000 2721-104/031-000 2721-104/037-000 2721-105/008-000 2721-105/026-000 2721-105/026-000/134-000 2721-105/031-000 2721-105/037-000 2721-106/008-000 2721-106/026-000 2721-106/031-000 2721-106/037-000 2721-107/008-000 2721-107/026-000 2721-107/031-000 2721-107/037-000 2721-108/008-000 2721-108/026-000 2721-108/031-000 2721-108/037-000 2721-109/008-000 2721-109/026-000 2721-109/031-000 2721-109/037-000 2721-110/008-000 2721-110/026-000 2721-110/031-000 2721-110/037-000 2721-111/008-000 2721-111/026-000 2721-111/037-000 2721-112/008-000 2721-112/026-000 2721-112/031-000 2721-112/037-000 2721-113/026-000 2721-114/008-000 2721-114/026-000 2721-114/031-000 2721-114/037-000 2721-115/008-000 2721-115/026-000 2721-115/026-000/136-000 2721-115/037-000 2721-116/008-000 2721-116/026-000 2721-116/031-000 2721-116/037-000 2721-120/008-000 2721-120/026-000 2721-120/031-000 2721-120/037-000 2721-202/008-000 2721-202/026-000 2721-202/031-000 2721-202/037-000 2721-203/008-000 2721-203/026-000 2721-203/031-000 2721-203/037-000 2721-204/008-000 2721-204/026-000 2721-204/031-000 2721-204/037-000 2721-205/008-000 2721-205/026-000 2721-205/031-000 2721-205/037-000 2721-206/008-000 2721-206/026-000 2721-206/031-000 2721-206/037-000 2721-207/008-000 2721-207/026-000 2721-207/031-000 2721-207/037-000 2721-208/008-000 2721-208/026-000 2721-208/031-000 2721-208/037-000 2721-209/008-000 2721-209/026-000 2721-209/031-000 2721-209/037-000 2721-210/008-000 2721-210/026-000 2721-210/031-000 2721-210/037-000 2721-211/008-000 2721-211/026-000 2721-211/031-000 2721-211/037-000 2721-212/008-000 2721-212/026-000 2721-212/031-000 2721-212/037-000
2721210/008000, 2721 210/008 000
