Datasheet Wago 2734-105/031-000 — Даташит
1-проводниковая розетка; 100% защита от неправильного подсоединения; Нажимная кнопка; зажимное кольцо; 1,5; Шаг контактов 3,5 мм; 5-пол.
Купить 2734-105/031-000 на РадиоЛоцман.Цены — от 1 224 до 1 837 ₽6 предложений от 3 поставщиков HEADER MALE R/A 5POS | |||
| 2734-105/031-000 Wago | от 1 224 ₽ | ||
| 2734-105/031-000 Wago | 1 837 ₽ | ||
| 2734-105/031-000 Wago | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light gray |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | PL |
| Габариты: глубина | 20.4 mm / 0.803 inch |
| Fine-stranded conductor | 0.2 … 1.5 mm² / 24 … 16 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 0.75 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
| Fire load | 0.112 MJ |
| GTIN | 4055143294201 |
| Height | 13.5 mm / 0.531 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | Yes |
| Mounting type | Mounting flange |
| Number of Poles | 5 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 3.5 mm (0.138 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 320 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 160 В |
| Solid conductor | 0.2 … 1.5 mm² / 24 … 16 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Total number of connection points | 5 |
| Total number of potentials | 5 |
| Type of mounting | Feed-through mounting Panel mounting |
| Вес | 5.278 г |
| Ширина | 32.3 mm / 1.272 inch |
Серия: 2734 (100 из 121)
- 2734-102 2734-102/031-000 2734-102/037-000 2734-102/107-000 2734-103 2734-103/031-000 2734-103/037-000 2734-103/107-000 2734-104 2734-104/031-000 2734-104/033-000 2734-104/037-000 2734-104/107-000 2734-105 2734-105/031-000 2734-105/037-000 2734-105/107-000 2734-106 2734-106/031-000 2734-106/033-000 2734-106/037-000 2734-106/107-000 2734-107 2734-107/031-000 2734-107/037-000 2734-107/107-000 2734-108 2734-108/031-000 2734-108/037-000 2734-108/107-000 2734-109 2734-109/031-000 2734-109/037-000 2734-109/107-000 2734-110 2734-110/027-000 2734-110/037-000 2734-110/107-000 2734-111 2734-111/027-000 2734-111/037-000 2734-111/107-000 2734-112 2734-112/027-000 2734-112/031-000 2734-112/037-000 2734-112/107-000 2734-113 2734-113/027-000 2734-113/037-000 2734-113/107-000 2734-114 2734-114/027-000 2734-114/037-000 2734-114/107-000 2734-116 2734-116/027-000 2734-116/037-000 2734-116/107-000 2734-118 2734-118/027-000 2734-118/037-000 2734-118/107-000 2734-120 2734-120/027-000 2734-120/037-000 2734-120/107-000 2734-124 2734-124/027-000 2734-124/037-000 2734-124/107-000 2734-202 2734-202/031-000 2734-202/037-000 2734-203 2734-203/031-000 2734-203/037-000 2734-204 2734-204/031-000 2734-204/037-000 2734-205 2734-205/031-000 2734-205/037-000 2734-206 2734-206/031-000 2734-206/037-000 2734-208 2734-208/031-000 2734-208/037-000 2734-209 2734-209/031-000 2734-209/037-000 2734-210 2734-210/027-000 2734-210/031-000 2734-210/037-000 2734-212 2734-212/027-000 2734-212/031-000 2734-212/037-000
2734105/031000, 2734 105/031 000
