Заказные клавиатуры Accord по вашему ТЗ
Datasheet Wago 267 — Даташит
Серия267
Datasheet Wago 267
Wago 267 Wago 267
Parameters / Models267-101
267-101
267-109
267-109
267-110
267-110
267-113
267-113
267-114
267-114
267-115
267-115
267-119
267-119
267-120
267-120
267-123
267-123
267-124
267-124
267-125
267-125
267-140
267-140
267-141
267-141
267-143
267-143
267-163
267-163
267-164
267-164
267-165
267-165
267-166
267-166
267-167
267-167
267-173
267-173
267-174
267-174
267-175
267-175
267-177
267-177
267-223
267-223
267-224
267-224
267-225
267-225
267-226
267-226
267-232
267-232
267-233
267-233
267-234
267-234
267-303
267-303
267-304
267-304
267-305
267-305
267-313
267-313
267-314
267-314
267-315
267-315
267-328
267-328
267-412
267-412
267-435
267-435
267-437
267-437
267-501
267-501
267-501/004-000
267-501/004-000
267-506
267-506
267-507
267-507
267-510
267-510
267-510/004-000
267-510/004-000
267-516
267-516
267-518
267-518
267-519
267-519
267-520
267-520
267-521
267-521
Clamping spring materialChrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)
Цветgraywhitewhitewhitewhitewhitewhitewhitewhitewhitewhitewhitewhitewhitewhitewhitewhitewhitewhitewhite/graywhite/graywhite/graywhite/graywhitewhitewhitewhitewhitewhitegraywhitewhitewhitewhitewhitewhite
Connection technologyPUSH WIRE®PUSH WIRE®PUSH WIRE®PUSH WIRE®PUSH WIRE®PUSH WIRE®PUSH WIRE®PUSH WIRE®PUSH WIRE®PUSH WIRE®PUSH WIRE®PUSH WIRE®PUSH WIRE®PUSH WIRE®PUSH WIRE®PUSH WIRE®PUSH WIRE®PUSH WIRE®PUSH WIRE®IDCPUSH WIRE®PUSH WIRE®PUSH WIRE®
Connection technology 2PUSH WIRE®
Connection type (1)PUSH WIRE® connection
Connection type (2)PUSH WIRE® connection
Contact materialElectrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)
Contact platingtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-plated
Country of originPLPLPLPLPLPLPLPLPLPLPLDEDEDEPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLCNPLPLPLPLPLPLPLPLPLPLPLPLPL
Габариты: глубина32 mm / 1.26 inch32 mm / 1.26 inch32 mm / 1.26 inch32 mm / 1.26 inch32 mm / 1.26 inch32 mm / 1.26 inch32 mm / 1.26 inch32 mm / 1.26 inch32 mm / 1.26 inch42 mm / 1.654 inch42 mm / 1.654 inch42 mm / 1.654 inch42 mm / 1.654 inch42 mm / 1.654 inch42 mm / 1.654 inch42 mm / 1.654 inch42 mm / 1.654 inch42 mm / 1.654 inch42 mm / 1.654 inch39 mm / 1.535 inch39 mm / 1.535 inch39 mm / 1.535 inch
Fire load, MJ0.0230.0230.0230.1170.140.1630.0230.0230.1180.1410.1640.1020.1290.1270.1450.1680.1910.2140.2370.1460.1690.1920.2380.1670.190.2130.2360.1180.1410.1640.1110.1110.1110.1110.1110.1110.2790.1430.2440.2440.1810.1810.1810.1810.2730.2730.2730.2730.2730.2730.281
Flammability class per UL94V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0
GTIN404491849929340454544978804045454479343404491849947740449184995074044918499514404545449791040454544793504044918499538404491849955240449184995694017332145039401733214504640173322002954044918499651404491849968240449184997054044918499712404491849972940449184997364044918499774404491849979840449184998354044918966962405082165606740551433271904055143327237404545427238840454542742384045454274245404545441541940454544154264045454415433404545441544040454544154574045454415464404545457221140508218302904044918997829404491899783640449185464924044918546591404545436825840454544989794044918546706404491854676840449185468984045454368302404545437492140454544989864050821307914
Height15.5 mm / 0.61 inch18 mm / 0.709 inch
Height from the surface34 mm / 1.339 inch34 mm / 1.339 inch34 mm / 1.339 inch34 mm / 1.339 inch34 mm / 1.339 inch34 mm / 1.339 inch14 mm / 0.551 inch11.8 mm / 0.465 inch11.8 mm / 0.465 inch34 mm / 1.339 inch34 mm / 1.339 inch34 mm / 1.339 inch34 mm / 1.339 inch34 mm / 1.339 inch34 mm / 1.339 inch34 mm / 1.339 inch34 mm / 1.339 inch34 mm / 1.339 inch19 mm / 0.748 inch19 mm / 0.748 inch19 mm / 0.748 inch19 mm / 0.748 inch19 mm / 0.748 inch19 mm / 0.748 inch21.5 mm / 0.846 inch18 mm / 0.709 inch18 mm / 0.709 inch
Insulating materialPolyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)
Legend (ratings)(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2
Material groupIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIII
Number of Poles1113451134555534567345734562343453454774477454
Number of connection points1
Number of connection points (connection type)1
Number of connection types111111111111111111111111111111111111111111111111112
Number of levels1112
Packaging typebagbagbagbagbagbagbagbagbagbagbagbagbagbagbagbagbagbagbagbagbagbagbagbagbagbagbagbagbagbagbagbagbagbag
Product Group8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)8 (Misc. Chassis Mount Blocks)
Rated current, A66666666666666666666666666616161616161616661616161616161616161616
Rated current (2), A666666
Rated impulse voltage (III / 2), kV44444444444444444444444444444444444444444444444444
Rated voltage (III / 2), В500500500500500500500500500500500500500500500500500500500500500500500500500500500500500500500500500500500500500500500500500500500500500500500500500500
Solid conductor1.5 … 2.5 mm² / …1.5 … 2.5 mm² / …1.5 … 2.5 mm² / …1.5 … 2.5 mm² / 16 … 14 AWG
Solid conductor (2)0.75 … 1.5 mm² / 18 … 16 AWG
Strip length8 mm / 0.31 Inch8 mm / 0.31 Inch8 mm / 0.31 Inch8 mm / 0.31 Inch8 mm / 0.31 Inch8 mm / 0.31 Inch8 mm / 0.31 Inch8 mm / 0.31 Inch8 mm / 0.31 Inch8 mm / 0.31 Inch8 mm / 0.31 Inch16 … 18 mm / 0.63 … 0.71 Inch16 … 18 mm / 0.63 … 0.71 Inch16 … 18 mm / 0.63 … 0.71 Inch8 mm / 0.31 Inch8 mm / 0.31 Inch8 mm / 0.31 Inch8 mm / 0.31 Inch8 mm / 0.31 Inch8 mm / 0.31 Inch8 mm / 0.31 Inch8 mm / 0.31 Inch8 mm / 0.31 Inch8 mm / 0.31 Inch8 mm / 0.31 Inch8 mm / 0.31 Inch8 mm / 0.31 Inch11 … 12 mm / 0.43 … 0.47 Inch11 … 12 mm / 0.43 … 0.47 Inch11 … 12 mm / 0.43 … 0.47 Inch11 … 12 mm / 0.43 … 0.47 Inch11 … 12 mm / 0.43 … 0.47 Inch11 … 12 mm / 0.43 … 0.47 Inch11 … 12 mm / 0.43 … 0.47 Inch11 … 12 mm / 0.43 … 0.47 Inch11 … 12 mm / 0.43 … 0.47 Inch11 … 12 mm / 0.43 … 0.47 Inch
Strip length (2)11 … 12 mm / 0.43 … 0.47 Inch
Temperature stability, °C105105105105105105105105105105105105105105105105105105105105105105105105105105105105105105105105105105105105105105105105105105105105105105105105105105105
Total number of connection points87
Total number of potentials47
Вес, г1.471.4341.4346.097.339.031.4311.4316.217.689.153.644.44.32778.4949.96411.43412.9047.1448.61410.084137.9139.38310.85312.3235.386.858.3215.77417.8719.88615.05817.11419.1716.1744.9310.611.31913.92813.92810.58610.5619.36519.36519.40514.88816.47114.88819.615
Ширина32 mm / 1.26 inch32 mm / 1.26 inch32 mm / 1.26 inch32 mm / 1.26 inch32 mm / 1.26 inch32 mm / 1.26 inch30 mm / 1.181 inch30 mm / 1.181 inch30 mm / 1.181 inch26 mm / 1.024 inch26 mm / 1.024 inch26 mm / 1.024 inch26 mm / 1.024 inch26 mm / 1.024 inch26 mm / 1.024 inch26 mm / 1.024 inch26 mm / 1.024 inch26 mm / 1.024 inch39.1 mm / 1.539 inch39.1 mm / 1.539 inch39.1 mm / 1.539 inch39.1 mm / 1.539 inch39.1 mm / 1.539 inch39.1 mm / 1.539 inch42 mm / 1.654 inch40 mm / 1.575 inch34 mm / 1.339 inch35 mm / 1.378 inch35 mm / 1.378 inch
На английском языке: Datasheet Wago 267
Политика конфиденциальности
