Datasheet Wago 277 — Даташит
Серия277
Datasheet Wago 277
18 предложений от 8 поставщиков
Зажим крокодил с изолятором 54мм красный
27.712.19.35 ₽
Элитан
27.712.123 ₽
Microfind
27.712.1от 27 ₽
Элрус
27.712.138 ₽
Wago 277 Wago 277
Parameters / Models277-121
277-121
277-123
277-123
277-124
277-124
277-125
277-125
277-126
277-126
277-127
277-127
277-128
277-128
277-131
277-131
Clamping spring materialChrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)
Цветwhitewhitewhitewhitewhitewhitewhitewhite
Connection technologyPUSH WIRE®PUSH WIRE®PUSH WIRE®PUSH WIRE®PUSH WIRE®PUSH WIRE®PUSH WIRE®PUSH WIRE®
Contact materialElectrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)
Contact platingtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-plated
Country of originDEDEDEDEDEDEDEDE
Габариты: глубина40 mm / 1.575 inch37 mm / 1.457 inch37 mm / 1.457 inch37 mm / 1.457 inch40 mm / 1.575 inch40 mm / 1.575 inch40 mm / 1.575 inch40 mm / 1.575 inch
Fire load, MJ0.4440.1390.170.2010.727
Flammability class per UL94V0V0V0V0V0V0V0V0
GTIN40449184720504044918507370404491850739440449185074174045454356255404545435626240454543562794044918472364
Height31.4 mm / 1.236 inch35.4 mm / 1.394 inch35.4 mm / 1.394 inch35.4 mm / 1.394 inch30.8 mm / 1.213 inch30.8 mm / 1.213 inch30.8 mm / 1.213 inch31.4 mm / 1.236 inch
Insulating materialPolyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)
Legend (ratings)(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2
Material groupIIIIIIII
Number of Poles53453445
Number of connection types11111111
Packaging typebagbagbagbagbag
Rated current, A1610101010101016
Rated impulse voltage (III / 2), kV44444444
Rated voltage (III / 2), В400400400400400400400400
Strip length11 … 12 mm / 0.43 … 0.47 Inch10 … 11 mm / 0.39 … 0.43 Inch10 … 11 mm / 0.39 … 0.43 Inch10 … 11 mm / 0.39 … 0.43 Inch10 … 11 mm / 0.39 … 0.43 Inch10 … 11 mm / 0.39 … 0.43 Inch10 … 11 mm / 0.39 … 0.43 Inch11 … 12 mm / 0.43 … 0.47 Inch
Temperature stability, °C105105105105105105105105
Вес, г23.6228.510.5412.8812.65614.5316.633.8
Ширина30 mm / 1.181 inch25 mm / 0.984 inch25 mm / 0.984 inch25 mm / 0.984 inch45 mm / 1.772 inch45 mm / 1.772 inch45 mm / 1.772 inch30 mm / 1.181 inch
На английском языке: Datasheet Wago 277
