Datasheet Wago 730 — Даташит
Серия730
Datasheet Wago 730
730-103, Розетка 3-конт., автозачистка провода, оранжевая
307 ₽
M39012/73-0103
Оф. дистрибьютор
Wago 730
Parameters / Models730-103
730-103
730-106
730-106
730-113
730-113
730-116
730-116
730-123
730-123
730-126
730-126
Actuation typeOperating toolOperating tool
Clamping spring materialChrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)
Цветorangegrayorangegrayorangegray
Connection technologyIDCIDCCAGE CLAMP®CAGE CLAMP®IDCIDC
Connector connection typefor conductorsfor conductorsfor conductorsfor conductorsfor conductorsfor conductors
Contact materialBrassBrassElectrolytic copper (Ecu)Electrolytic copper (Ecu)BrassBrass
Contact platingtin-platedtin-platedtin-platedtin-platedtin-platedtin-plated
Contact type (pluggable connector)Female connector/socketFemale connector/socketMale connector/plugMale connector/plugFemale connector/socketFemale connector/socket
Country of originCNDEDEDEDE
Габариты: глубина23 mm / 0.906 inch30 mm / 1.181 inch22.5 mm / 0.886 inch30 mm / 1.181 inch23 mm / 0.906 inch30 mm / 1.181 inch
Fine-stranded conductor0.75 … 1.5 mm² / 18 … 16 AWG0.75 … 1.5 mm² / 18 … 16 AWG0.08 … 2.5 mm² / 28 … 14 AWG0.08 … 2.5 mm² / 28 … 14 AWG0.75 … 1.5 mm² / 18 … 16 AWG0.75 … 1.5 mm² / 18 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 1.5 mm²0.25 … 1.5 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 … 2.5 mm²0.25 … 2.5 mm²
Fire load, MJ0.1690.2730.2140.2920.1690.273
Flammability class per UL94V0V0V0V0V0V0
GTIN405082142971540449182534444044918508988404491852452040449186006374044918253468
Height27 mm / 1.063 inch16 mm / 0.63 inch35.5 mm / 1.398 inch29 mm / 1.142 inch27 mm / 1.063 inch
Insulating materialPolyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)
Legend (ratings)(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2
Limit temperature range-60 … +85 °C-60 … +85 °C-60 … +85 °C-60 … +85 °C-60 … +85 °C-60 … +85 °C
Material groupIIIIII
Mounting typeMounting flangeMounting flange
Number of Poles363636
Number of connection types111111
Number of levels111111
Packaging typebagbag
Product Group13 (Misc. Multi Conn. System)13 (Misc. Multi Conn. System)13 (Misc. Multi Conn. System)13 (Misc. Multi Conn. System)
Rated current, A101010101010
Rated impulse voltage (II / 2), kV666666
Rated impulse voltage (III / 2), kV666666
Rated impulse voltage (III / 3), kV666666
Rated voltage (II / 2), В100010001000100010001000
Rated voltage (III / 2), В630630630630630630
Rated voltage (III / 3), В500500500500500500
Solid conductor0.08 … 2.5 mm² / 28 … 14 AWG0.08 … 2.5 mm² / 28 … 14 AWG
Strip length8 … 9 mm / 0.31 … 0.35 Inch8 … 9 mm / 0.31 … 0.35 Inch
Total number of potentials363636
Вес, г7.06412.39.75916.7447.06411.728
Ширина26.5 mm / 1.043 inch43 mm / 1.693 inch30 mm / 1.181 inch43 mm / 1.693 inch26.5 mm / 1.043 inch43 mm / 1.693 inch
На английском языке: Datasheet Wago 730
