Datasheet Wago 769-607/005-000 — Даташит
1-проводная вилка; Защелкивающийся фланец; 4 mm²; Шаг контактов 5 мм; 7-пол.
1-CONDUCTOR MALE CONNECTOR, CAGE | |||
| 769-607/005-000 Wago | по запросу | ||
| Цвет | gray |
| Connectable conductor materials | Copper Aluminum |
| Connector connection type | for conductors |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | PL |
| Габариты: глубина | 40.8 mm / 1.606 inch |
| Fine-stranded conductor | 0.08 … 4 mm² / 28 … 12 AWG |
| Fire load | 0.47 MJ |
| GTIN | 4044918854498 |
| Height | 24.4 mm / 0.961 inch |
| Mounting type | Snap-in |
| Nominal cross section | 4 mm² |
| Number of Poles | 7 |
| Pin spacing | 5 mm / 0.197 inch |
| Product Group | 18 (X-COM-System) |
| Rated current | 32 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 500 В |
| Solid conductor | 0.08 … 4 mm² / 28 … 12 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Total number of connection points | 7 |
| Total number of potentials | 7 |
| Type of wiring | Front-entry wiring |
| Вес | 22.329 г |
| Ширина | 56.3 mm / 2.217 inch |
Серия: 769 (100 из 460)
- 769-504/000-016 769-505 769-505/000-006 769-505/000-016 769-506 769-506/000-006 769-506/000-016 769-512 769-512/000-006 769-512/000-016 769-513 769-513/000-006 769-513/000-016 769-515 769-515/000-006 769-515/000-016 769-602 769-602/001-000 769-602/002-000 769-602/004-000 769-602/005-000 769-602/006-000 769-603 769-603/001-000 769-603/002-000 769-603/004-000 769-603/005-000 769-603/006-000 769-604 769-604/001-000 769-604/002-000 769-604/004-000 769-604/005-000 769-604/006-000 769-605 769-605/001-000 769-605/002-000 769-605/004-000 769-605/005-000 769-605/006-000 769-606 769-606/001-000 769-606/002-000 769-606/004-000 769-606/005-000 769-606/006-000 769-607 769-607/001-000 769-607/002-000 769-607/004-000 769-607/005-000 769-607/006-000 769-608 769-608/001-000 769-608/002-000 769-608/004-000 769-608/005-000 769-608/006-000 769-609 769-609/001-000 769-609/002-000 769-609/004-000 769-609/005-000 769-609/006-000 769-610 769-610/001-000 769-610/002-000 769-610/004-000 769-610/005-000 769-610/006-000 769-611 769-611/001-000 769-611/002-000 769-611/004-000 769-611/005-000 769-611/006-000 769-612 769-612/001-000 769-612/002-000 769-612/004-000 769-612/005-000 769-612/006-000 769-613 769-613/001-000 769-613/002-000 769-613/004-000 769-613/005-000 769-613/006-000 769-614 769-614/001-000 769-614/002-000 769-614/004-000 769-614/005-000 769-614/006-000 769-615 769-615/001-000 769-615/002-000 769-615/004-000 769-615/005-000 769-615/006-000
769607/005000, 769 607/005 000
