Datasheet Wago 769-632/004-000 — Даташит
Вилка THT; 1.0 x 1.0 mm solder pin; прямые; Шаг контактов 5 мм; 2-пол.
| THT MALE HEADER; 1.0 X 1.0 MM SO | |||
| 769-632/004-000 Wago | по запросу | ||
| 769-632/004-000 | по запросу | ||
| Цвет | gray |
| Connector connection type | for PCBs |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | PL |
| Габариты: глубина | 18.3 mm / 0.72 inch |
| Fire load | 0.097 MJ |
| GTIN | 4044918270588 |
| Height from the surface | 22.2 mm / 0.874 inch |
| Mating direction to the PCB | 90 ° |
| Mismating protection | No |
| Mounting type | Mounting flange |
| Number of Poles | 2 |
| Number of levels | 1 |
| PCB contact | THT |
| Pin spacing | 5 mm / 0.197 inch |
| Product Group | 18 (X-COM-System) |
| Rated current | 32 A |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (III / 2) | 500 В |
| Rated voltage (III / 3) | 250 В |
| Solder pin dimensions | Solder pin 1 x 1 mm |
| Total number of potentials | 2 |
| Вес | 3.833 г |
| Ширина | 24.7 mm / 0.972 inch |
Серия: 769 (100 из 460)
- 769-608/002-000 769-608/004-000 769-608/005-000 769-608/006-000 769-609 769-609/001-000 769-609/002-000 769-609/004-000 769-609/005-000 769-609/006-000 769-610 769-610/001-000 769-610/002-000 769-610/004-000 769-610/005-000 769-610/006-000 769-611 769-611/001-000 769-611/002-000 769-611/004-000 769-611/005-000 769-611/006-000 769-612 769-612/001-000 769-612/002-000 769-612/004-000 769-612/005-000 769-612/006-000 769-613 769-613/001-000 769-613/002-000 769-613/004-000 769-613/005-000 769-613/006-000 769-614 769-614/001-000 769-614/002-000 769-614/004-000 769-614/005-000 769-614/006-000 769-615 769-615/001-000 769-615/002-000 769-615/004-000 769-615/005-000 769-615/006-000 769-632 769-632/000-036 769-632/003-000 769-632/003-036 769-632/004-000 769-632/007-000 769-633 769-633/000-036 769-633/003-000 769-633/003-036 769-633/004-000 769-633/007-000 769-634 769-634/000-036 769-634/003-000 769-634/003-036 769-634/004-000 769-634/007-000 769-635 769-635/000-036 769-635/003-000 769-635/003-036 769-635/004-000 769-635/007-000 769-636 769-636/003-000 769-636/003-036 769-636/004-000 769-636/007-000 769-637 769-637/003-000 769-637/004-000 769-637/007-000 769-638 769-638/003-000 769-638/004-000 769-638/007-000 769-639 769-639/003-000 769-639/004-000 769-639/007-000 769-640 769-640/003-000 769-640/004-000 769-640/007-000 769-641 769-641/003-000 769-641/004-000 769-641/007-000 769-642 769-642/003-000 769-642/004-000 769-642/007-000 769-643
769632/004000, 769 632/004 000
