Datasheet Wago 770-245/062-000 — Даташит
Серия770
Модель770-245/062-000
Разъем; 5-пол.; Код. B
17 предложений от 7 поставщиков
, FXO-LC52 Series 245.76MHz 5x3.2mm 3.3V ±50ppm SMT XpressO Crystal Oscillator
Зенер
Россия и страны ТС
770-245
от 870 ₽
770-245
от 1 040 ₽
IDT
1 531 ₽
Actuation typeOperating tool Push-in
CodingB
Цветgray
Country of originDE
Degree of protectionIP20
Габариты: глубина37.5 mm / 1.476 inch
Fine-stranded conductor0.5 … 4 mm² / 20 … 12 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 1.5 mm² / 20 … 16 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 2.5 mm² / 20 … 14 AWG
Fine-stranded conductor with ferrule, push-in termination, from1.5 mm² / 16 AWG
Fire load0.273 MJ
GTIN4050821454984
Height12.9 mm / 0.508 inch
Locking leverнет
MarkingN PE 3 2 1
Nominal cross section4 mm²
Note (strip length)see also packaging or instructions
Number of Poles5
Pin spacing10 mm (0.394 inch)
Potential markingN PE 3 2 1
Rated current25 A
Rated voltage (III / 3)400 В
Solid conductor0.5 … 4 mm² / 20 … 12 AWG
Solid conductor, push-in termination1.5 … 4 mm² / 16 … 12 AWG
Stranded conductor0.5 … 2.5 mm² / 20 … 14 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points10
Total number of potentials5
Вес16.085 г
Ширина50 mm / 1.969 inch
770245/062000, 770 245/062 000
На английском языке: Datasheet Wago 770-245/062-000
