Datasheet Wago 770-282 — Даташит
Серия770
Модель770-282
Разъем; 2-пол.; Код. B
5 предложений от 5 поставщиков
Alligator Clip Test Lead, 3 фут, 914 мм, Черный, 10 А, 60 В DC
Элитан
MP770282
Multicomp
663 ₽
MP770282
703 ₽
MP770282
Multicomp Pro
1 113 ₽
Wago 770-282
Actuation typeOperating tool Push-in
CodingB
Цветpink
Country of originDE
Degree of protectionIP20
Габариты: глубина37.5 mm / 1.476 inch
Fine-stranded conductor0.5 … 4 mm² / 20 … 12 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 1.5 mm² / 20 … 16 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 2.5 mm² / 20 … 14 AWG
Fine-stranded conductor with ferrule, push-in termination, from1.5 mm² / 16 AWG
Fire load0.114 MJ
GTIN4050821541905
Height12.9 mm / 0.508 inch
Locking leverнет
Marking1 2
Nominal cross section4 mm²
Note (strip length)see also packaging or instructions
Number of Poles2
Pin spacing10 mm (0.394 inch)
Potential marking1 2
Product Group20 (WINSTA)
Rated current25 A
Rated voltage (III / 3)250 В
Solid conductor0.5 … 4 mm² / 20 … 12 AWG
Solid conductor, push-in termination1.5 … 4 mm² / 16 … 12 AWG
Stranded conductor0.5 … 2.5 mm² / 20 … 14 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points4
Total number of potentials2
Вес6.59 г
Ширина20 mm / 0.787 inch
На английском языке: Datasheet Wago 770-282
