Datasheet Wago 770-283 — Даташит
Разъем; 3-пол.; Код. B
![]() 6 предложений от 6 поставщиков Alligator Clip Test Lead, 36 ", 914 мм, Красный, 10 А, 30 В AC | |||
MP770283 Multicomp | 663 ₽ | ||
MP770283 | 768 ₽ | ||
MP770283 | 776 ₽ | ||
770-283 Wago | по запросу |
Actuation type | Operating tool Push-in |
Coding | B |
Цвет | pink |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | DE |
Degree of protection | IP20 |
Габариты: глубина | 37.5 mm / 1.476 inch |
Fine-stranded conductor | 0.5 … 4 mm² / 20 … 12 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² / 20 … 16 AWG |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² / 20 … 14 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 1.5 mm² / 16 AWG |
Fire load | 0.162 MJ |
GTIN | 4050821451129 |
Height | 12.9 mm / 0.508 inch |
Locking lever | нет |
Locking of plug-in connection | locking lever |
Marking | 1 2 3 |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Nominal cross section | 4 mm² |
Note (strip length) | see also packaging or instructions |
Number of Poles | 3 |
Pin spacing | 10 mm (0.394 inch) |
Potential marking | 1 2 3 |
Product Group | 20 (WINSTA) |
Rated current | 25 A |
Rated voltage (III / 3) | 250 В |
Retention force of a plug-in connection | when locked: > 80N |
Solid conductor | 0.5 … 4 mm² / 20 … 12 AWG |
Solid conductor, push-in termination | 1.5 … 4 mm² / 16 … 12 AWG |
Stranded conductor | 0.5 … 2.5 mm² / 20 … 14 AWG |
Strip length | 9 mm / 0.35 Inch |
Surrounding air (operating) temperature | -35 … 85 °C |
Total number of connection points | 6 |
Total number of potentials | 3 |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 8.49 г |
Ширина | 30 mm / 1.181 inch |
Серия: 770 (100 из 608)
- 770-243/060-000 770-243/062-000 770-243/081-000 770-244 770-244/060-000 770-244/062-000 770-244/064-000 770-244/081-000 770-245 770-245/060-000 770-245/062-000 770-245/064-000 770-252 770-252/060-000 770-253 770-253/060-000 770-253/062-000 770-253/081-000 770-254 770-254/060-000 770-254/062-000 770-254/064-000 770-254/081-000 770-255 770-255/060-000 770-255/062-000 770-255/064-000 770-262 770-263 770-263/071-000 770-263/073-000 770-264 770-264/071-000 770-264/072-000 770-264/073-000 770-265 770-265/073-000 770-272 770-273 770-273/071-000 770-273/073-000 770-274 770-274/071-000 770-274/072-000 770-274/073-000 770-275 770-275/073-000 770-282 770-282/080-000 770-282/082-000 770-283 770-283/081-000 770-283/082-000 770-284 770-284/081-000 770-285 770-285/080-000 770-285/082-000 770-292 770-292/080-000 770-292/082-000 770-293 770-293/081-000 770-293/082-000 770-294 770-294/081-000 770-295 770-295/080-000 770-295/082-000 770-305 770-3105 770-3105/011-000 770-3115 770-3115/011-000 770-315 770-317 770-318 770-319 770-320 770-321 770-325 770-335 770-337 770-338 770-339 770-340 770-341 770-354 770-360 770-382 770-383 770-401 770-405 770-408 770-415 770-418 770-425 770-428 770-435 770-438
