Datasheet Wago 770-292/080-000 — Даташит
Серия770
Модель770-292/080-000
Штекер; 2-пол.; Код. B
Actuation typeOperating tool Push-in
CodingB
Цветpink
Country of originDE
Degree of protectionIP20
Габариты: глубина37.5 mm / 1.476 inch
Fine-stranded conductor0.5 … 4 mm² / 20 … 12 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 1.5 mm² / 20 … 16 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 2.5 mm² / 20 … 14 AWG
Fine-stranded conductor with ferrule, push-in termination, from1.5 mm² / 16 AWG
Fire load0.127 MJ
GTIN4050821553182
Height12.9 mm / 0.508 inch
Locking leverнет
MarkingI+ I-
Nominal cross section4 mm²
Note (strip length)see also packaging or instructions
Number of Poles2
Pin spacing10 mm (0.394 inch)
Potential markingI+ I-
Rated current25 A
Rated voltage (III / 3)250 В
Solid conductor0.5 … 4 mm² / 20 … 12 AWG
Solid conductor, push-in termination1.5 … 4 mm² / 16 … 12 AWG
Stranded conductor0.5 … 2.5 mm² / 20 … 14 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points4
Total number of potentials2
Вес6.536 г
Ширина20 mm / 0.787 inch
770292/080000, 770 292/080 000
На английском языке: Datasheet Wago 770-292/080-000
