Datasheet Wago 770-325 — Даташит
Серия770
Модель770-325
Разъем; с корпусом разгрузки натяжения; 5-пол.; Код. A
Wago 770-325 Wago 770-325
Actuation typeOperating tool Push-in
CodingA
Цветwhite
Connectable sheathed cable diameter9 … 13 mm
Country of originDE
Degree of protectionIP20
Габариты: глубина75.9 mm / 2.988 inch
Fine-stranded conductor0.5 … 4 mm² / 20 … 12 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 1.5 mm² / 20 … 16 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 2.5 mm² / 20 … 14 AWG
Fine-stranded conductor with ferrule, push-in termination, from1.5 mm² / 16 AWG
Fire load0.622 MJ
GTIN4044918252515
Height17 mm / 0.669 inch
Locking leverнет
MarkingN ⏚ L1 L2 L3
Mismating protectionYes
Nominal cross section4 mm²
Note (strip length)see also packaging or instructions
Number of Poles5
Pin spacing10 mm (0.394 inch)
Potential markingN ⏚ L1 L2 L3
Product Group20 (WINSTA)
Rated current25 A
Rated voltage (III / 3)400 В
Solid conductor0.5 … 4 mm² / 20 … 12 AWG
Solid conductor, push-in termination1.5 … 4 mm² / 16 … 12 AWG
Strain reliefStrain relief housing
Stranded conductor0.5 … 2.5 mm² / 20 … 14 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points5
Total number of potentials5
Вес28.963 г
Ширина54.6 mm / 2.15 inch
На английском языке: Datasheet Wago 770-325
