Datasheet Wago 770-626 — Даташит
Т-образный распределительный соединитель; 4-пол.; Код. A; 1 вход; 2 вывода; 2 фиксирующих рычага
Купить 770-626 на РадиоЛоцман.Цены — от 323 до 551 ₽ T-DISTRIBUTION CONNECTOR 4-POLE | |||
| 770-626 WINSTA 25A 400V 4- pin Чёрн.пластм. диод | 323 ₽ | ||
| 770-626 Wago | 551 ₽ | ||
| 770-626 Wago | по запросу | ||
| Coding | A |
| Цвет | black |
| Contact material | Copper or copper alloy, surface-treated |
| Contact type (pluggable connector) | Socket/plug |
| Country of origin | DE |
| Degree of protection | IP20 |
| Габариты: глубина | 48.9 mm / 1.925 inch |
| Fire load | 0.419 MJ |
| GTIN | 4044918935074 |
| Ground function | with preceding GND contact |
| Height | 36.1 mm / 1.421 inch |
| Locking lever | да |
| Locking of plug-in connection | locking lever |
| Marking | N ⏚ 2|L 1|L' |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 4 |
| Pin spacing | 10 mm (0.394 inch) |
| Potential marking | N ⏚ 2/L 1/L' |
| Rated current | 25 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 400 В |
| Retention force of a plug-in connection | when locked: > 80N |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total number of potentials | 4 |
| Type of distribution connector | T-distribution connector |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 21 г |
| Ширина | 44 mm / 1.732 inch |
Серия: 770 (100 из 608)
- 770-502/041-000 770-502/042-000 770-503 770-503/021-000 770-503/023-000 770-503/032-000 770-503/035-000 770-503/038-000 770-504 770-504/023-000 770-505 770-505/021-000 770-505/023-000 770-506/029-000 770-507/047-000 770-512/041-000 770-512/042-000 770-513 770-513/021-000 770-513/023-000 770-513/032-000 770-513/035-000 770-513/038-000 770-514 770-514/023-000 770-515 770-515/021-000 770-515/023-000 770-516/029-000 770-517/047-000 770-523 770-601 770-603 770-605 770-606 770-607 770-608 770-609 770-611 770-615 770-617 770-618 770-619 770-620 770-621 770-622 770-6223 770-623 770-624 770-625 770-626 770-627 770-630 770-633 770-634 770-635 770-636 770-637 770-638 770-640 770-643 770-644 770-645 770-653 770-655 770-656 770-657 770-658 770-659 770-661 770-665 770-667 770-670 770-671 770-672 770-673 770-674 770-675 770-676 770-677 770-680 770-683 770-684 770-685 770-686 770-687 770-688 770-690 770-693 770-694 770-695 770-703 770-703/009-000 770-704 770-704/009-000 770-705 770-705/009-000 770-713 770-713/007-000 770-714
