Datasheet Wago 770-690 — Даташит
Распределительный соединитель с трех фаз на одну; 2 L2; 1 5-контактный штекер; 1 5-контактная розетка; 1 3-контактная розетка; 2 3-контактных розетки; 1 3-контактная розетка
| 770690-4 TE Connectivity | 7.25 ₽ | ||
| Coding | A |
| Цвет | white |
| Contact material | Copper or copper alloy, surface-treated |
| Contact type (pluggable connector) | Socket/plug |
| Country of origin | DE |
| Degree of protection | IP20 |
| Габариты: глубина | 62.75 mm / 2.47 inch |
| Fire load | 1.359 MJ |
| GTIN | 4045454530945 |
| Height | 41.1 mm / 1.618 inch |
| Locking lever | да |
| Locking of plug-in connection | locking lever |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 5 |
| Pin spacing | 10 mm (0.394 inch) |
| Rated current | 25 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated impulse voltage (III / 3) 2 | 4 kV |
| Rated voltage (III / 3) | 400 В |
| Rated voltage (III / 3) 2 | 250 В |
| Retention force of a plug-in connection | when locked: > 80N |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total number of potentials | 5 |
| Type of distribution connector | Three-phase to single-phase distribution connector |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 87.5 г |
| Ширина | 64.8 mm / 2.551 inch |
Серия: 770 (100 из 608)
- 770-609 770-611 770-615 770-617 770-618 770-619 770-620 770-621 770-622 770-6223 770-623 770-624 770-625 770-626 770-627 770-630 770-633 770-634 770-635 770-636 770-637 770-638 770-640 770-643 770-644 770-645 770-653 770-655 770-656 770-657 770-658 770-659 770-661 770-665 770-667 770-670 770-671 770-672 770-673 770-674 770-675 770-676 770-677 770-680 770-683 770-684 770-685 770-686 770-687 770-688 770-690 770-693 770-694 770-695 770-703 770-703/009-000 770-704 770-704/009-000 770-705 770-705/009-000 770-713 770-713/007-000 770-714 770-714/007-000 770-715 770-715/007-000 770-723 770-723/009-000 770-724 770-724/009-000 770-725 770-725/009-000 770-733 770-733/007-000 770-734 770-734/007-000 770-735 770-735/007-000 770-743 770-743/060-000 770-743/062-000 770-744 770-744/060-000 770-744/062-000 770-744/064-000 770-745 770-745/060-000 770-745/062-000 770-745/064-000 770-753 770-753/060-000 770-753/062-000 770-754 770-754/060-000 770-754/062-000 770-754/064-000 770-755 770-755/060-000 770-755/062-000 770-755/064-000
