Datasheet Wago 770-703/009-000 — Даташит
Серия770
Модель770-703/009-000
Защелкивающаяся розетка; с выступающим соединительным устройством; 3-пол.; Код. A
Actuation typeOperating tool Push-in
CodingA
Цветblack
Country of originDE
Degree of protectionIP20
Габариты: глубина37.5 mm / 1.476 inch
Designwith protruding interface
Fine-stranded conductor0.5 … 4 mm² / 20 … 12 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 1.5 mm² / 20 … 16 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 2.5 mm² / 20 … 14 AWG
Fine-stranded conductor with ferrule, push-in termination, from1.5 mm² / 16 AWG
Fire load0.18 MJ
GTIN4055143722414
Gehäuseblechstärke0.5 … 2 mm / 0.02 … 0.079 inch
Height18.5 mm / 0.728 inch
Locking leverда
MarkingL ⏚ N
Mismating protectionYes
Mounting typeSnap-in
Nominal cross section4 mm²
Note (strip length)see also packaging or instructions
Number of Poles3
Pin spacing10 mm (0.394 inch)
Potential markingL ⏚ N
Product Group20 (WINSTA)
Rated current25 A
Rated voltage (III / 3)250 В
Solid conductor0.5 … 4 mm² / 20 … 12 AWG
Solid conductor, push-in termination1.5 … 4 mm² / 16 … 12 AWG
Stranded conductor0.5 … 2.5 mm² / 20 … 14 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points6
Total number of potentials3
Вес10.241 г
Ширина35.5 mm / 1.398 inch
770703/009000, 770 703/009 000
На английском языке: Datasheet Wago 770-703/009-000
