Оптопары и оптореле Megawin
Datasheet Wago 770-733/007-000 — Даташит
Серия770
Модель770-733/007-000
Защелкивающийся штекер; с прямым заземляющим контактом; 3-пол.; Код. A
Actuation typeOperating tool Push-in
CodingA
Цветwhite
Country of originDE
Degree of protectionIP20
Габариты: глубина36 mm / 1.417 inch
Designwith direct ground contact
Direct ground contact to DIN-rail/drilled hole/housing1
Fine-stranded conductor0.5 … 4 mm² / 20 … 12 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 1.5 mm² / 20 … 16 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 2.5 mm² / 20 … 14 AWG
Fine-stranded conductor with ferrule, push-in termination, from1.5 mm² / 16 AWG
Fire load0.259 MJ
GTIN4045454431426
Gehäuseblechstärke0.5 … 2 mm / 0.02 … 0.079 inch
Height17.5 mm / 0.689 inch
Locking leverда
MarkingL ⏚ N
Mismating protectionYes
Mounting typeSnap-in
Nominal cross section4 mm²
Note (strip length)see also packaging or instructions
Number of Poles3
Pin spacing10 mm (0.394 inch)
Potential markingL ⏚ N
Rated current25 A
Rated voltage (III / 3)250 В
Solid conductor0.5 … 4 mm² / 20 … 12 AWG
Solid conductor, push-in termination1.5 … 4 mm² / 16 … 12 AWG
Stranded conductor0.5 … 2.5 mm² / 20 … 14 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points6
Total number of potentials3
Вес13.949 г
Ширина35.5 mm / 1.398 inch
770733/007000, 770 733/007 000
На английском языке: Datasheet Wago 770-733/007-000
