Datasheet Wago 770-734/007-000 — Даташит
Защелкивающийся штекер; с прямым заземляющим контактом; 4-пол.; Код. A
SNAP-IN PLUG WITH DIRECT GROUND | |||
| 770-734/007-000 Wago | по запросу | ||
| Actuation type | Operating tool Push-in |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Coding | A |
| Цвет | white |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for conductors |
| Contact material | Copper or copper alloy, surface-treated |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Degree of protection | IP20 |
| Габариты: глубина | 36 mm / 1.417 inch |
| Design | with direct ground contact |
| Direct ground contact to DIN-rail/drilled hole/housing | 1 |
| Fine-stranded conductor | 0.5 … 4 mm² / 20 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² / 20 … 16 AWG |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² / 20 … 14 AWG |
| Fine-stranded conductor with ferrule, push-in termination, from | 1.5 mm² / 16 AWG |
| Fire load | 0.331 MJ |
| GTIN | 4045454408466 |
| Gehäuseblechstärke | 0.5 … 2 mm / 0.02 … 0.079 inch |
| Ground function | with preceding GND contact |
| Height | 18.5 mm / 0.728 inch |
| Locking lever | да |
| Locking of plug-in connection | locking lever |
| Marking | N ⏚ 2|L 1|L' |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Mounting type | Snap-in |
| Nominal cross section | 4 mm² |
| Note (strip length) | see also packaging or instructions |
| Number of Poles | 4 |
| Pin spacing | 10 mm (0.394 inch) |
| Potential marking | N ⏚ 2/L 1/L' |
| Rated current | 25 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 400 В |
| Retention force of a plug-in connection | when locked: > 80N |
| Solid conductor | 0.5 … 4 mm² / 20 … 12 AWG |
| Solid conductor, push-in termination | 1.5 … 4 mm² / 16 … 12 AWG |
| Stranded conductor | 0.5 … 2.5 mm² / 20 … 14 AWG |
| Strip length | 9 mm / 0.35 Inch |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total number of connection points | 8 |
| Total number of potentials | 4 |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 17.714 г |
| Ширина | 45.5 mm / 1.791 inch |
Серия: 770 (100 из 608)
- 770-645 770-653 770-655 770-656 770-657 770-658 770-659 770-661 770-665 770-667 770-670 770-671 770-672 770-673 770-674 770-675 770-676 770-677 770-680 770-683 770-684 770-685 770-686 770-687 770-688 770-690 770-693 770-694 770-695 770-703 770-703/009-000 770-704 770-704/009-000 770-705 770-705/009-000 770-713 770-713/007-000 770-714 770-714/007-000 770-715 770-715/007-000 770-723 770-723/009-000 770-724 770-724/009-000 770-725 770-725/009-000 770-733 770-733/007-000 770-734 770-734/007-000 770-735 770-735/007-000 770-743 770-743/060-000 770-743/062-000 770-744 770-744/060-000 770-744/062-000 770-744/064-000 770-745 770-745/060-000 770-745/062-000 770-745/064-000 770-753 770-753/060-000 770-753/062-000 770-754 770-754/060-000 770-754/062-000 770-754/064-000 770-755 770-755/060-000 770-755/062-000 770-755/064-000 770-763 770-763/071-000 770-763/073-000 770-764 770-764/071-000 770-764/072-000 770-764/073-000 770-765 770-765/073-000 770-773 770-773/071-000 770-773/073-000 770-774 770-774/071-000 770-774/072-000 770-774/073-000 770-775 770-775/073-000 770-783 770-783/081-000 770-783/082-000 770-784 770-784/081-000 770-785 770-785/080-000
770734/007000, 770 734/007 000
