Оптопары и оптореле Megawin
Datasheet Wago 770-735/007-000 — Даташит
Серия770
Модель770-735/007-000
Защелкивающийся штекер; с прямым заземляющим контактом; 5-пол.; Код. A
7 предложений от 6 поставщиков
NYLON PLUG, FOR 733 & 770733 OPE
572 ₽
770735
970 ₽
Элитан
MP770735
Multicomp
6 794 ₽
Actuation typeOperating tool Push-in
CodingA
Цветwhite
Country of originDE
Degree of protectionIP20
Габариты: глубина36 mm / 1.417 inch
Designwith direct ground contact
Direct ground contact to DIN-rail/drilled hole/housing1
Fine-stranded conductor0.5 … 4 mm² / 20 … 12 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 1.5 mm² / 20 … 16 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 2.5 mm² / 20 … 14 AWG
Fine-stranded conductor with ferrule, push-in termination, from1.5 mm² / 16 AWG
Fire load0.398 MJ
GTIN4055143594141
Gehäuseblechstärke0.5 … 2 mm / 0.02 … 0.079 inch
Height18.5 mm / 0.728 inch
Locking leverда
MarkingN ⏚ L1 L2 L3
Mismating protectionYes
Mounting typeSnap-in
Nominal cross section4 mm²
Note (strip length)see also packaging or instructions
Number of Poles5
Pin spacing10 mm (0.394 inch)
Potential markingN ⏚ L1 L2 L3
Rated current25 A
Rated voltage (III / 3)400 В
Solid conductor0.5 … 4 mm² / 20 … 12 AWG
Solid conductor, push-in termination1.5 … 4 mm² / 16 … 12 AWG
Stranded conductor0.5 … 2.5 mm² / 20 … 14 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points10
Total number of potentials5
Вес21.472 г
Ширина55.5 mm / 2.185 inch
770735/007000, 770 735/007 000
На английском языке: Datasheet Wago 770-735/007-000
