Datasheet Wago 770-743/062-000 — Даташит
Серия770
Модель770-743/062-000
Защелкивающаяся розетка; 3-пол.; Код. B
52 предложений от 23 поставщиков
AMP - TE CONNECTIVITY - 1-770743-0 - Pin Header, Wire-to-Board, 4.14 мм, 2 ряд(-ов), 10 контакт(-ов), Through Hole Straight
TE Connectivity
95 ₽
Элрус
TE Connectivity
от 262 ₽
Эиком
TE Connectivity
от 329 ₽
TradeElectronics
TE Connectivity
Actuation typeOperating tool Push-in
CodingB
Цветgray
Country of originDE
Degree of protectionIP20
Габариты: глубина36 mm / 1.417 inch
Fine-stranded conductor0.5 … 4 mm² / 20 … 12 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 1.5 mm² / 20 … 16 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 2.5 mm² / 20 … 14 AWG
Fine-stranded conductor with ferrule, push-in termination, from1.5 mm² / 16 AWG
Fire load0.231 MJ
GTIN4050821553298
Gehäuseblechstärke0.5 … 2 mm / 0.02 … 0.079 inch
Height17.5 mm / 0.689 inch
Locking leverда
Marking2 PE 1
Mounting typeSnap-in
Nominal cross section4 mm²
Note (strip length)see also packaging or instructions
Number of Poles3
Pin spacing10 mm (0.394 inch)
Potential marking2 PE 1
Rated current25 A
Rated voltage (III / 3)250 В
Solid conductor0.5 … 4 mm² / 20 … 12 AWG
Solid conductor, push-in termination1.5 … 4 mm² / 16 … 12 AWG
Stranded conductor0.5 … 2.5 mm² / 20 … 14 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points6
Total number of potentials3
Вес11.895 г
Ширина35.5 mm / 1.398 inch
770743/062000, 770 743/062 000
На английском языке: Datasheet Wago 770-743/062-000
