Datasheet Wago 770-764 — Даташит
Серия770
Модель770-764
Защелкивающаяся розетка; 4-пол.; Код. B
1 489 ₽
Wago 770-764
Actuation typeOperating tool Push-in
CodingB
Цветlight green
Country of originDE
Degree of protectionIP20
Габариты: глубина36 mm / 1.417 inch
Fine-stranded conductor0.5 … 4 mm² / 20 … 12 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 1.5 mm² / 20 … 16 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 2.5 mm² / 20 … 14 AWG
Fine-stranded conductor with ferrule, push-in termination, from1.5 mm² / 16 AWG
Fire load0.301 MJ
GTIN4050821445760
Gehäuseblechstärke0.5 … 2 mm / 0.02 … 0.079 inch
Height18.5 mm / 0.728 inch
Locking leverда
Marking1 2 3 4
Mounting typeSnap-in
Nominal cross section4 mm²
Note (strip length)see also packaging or instructions
Number of Poles4
Pin spacing10 mm (0.394 inch)
Potential marking1 2 3 4
Product Group20 (WINSTA)
Rated current25 A
Rated voltage (III / 3)400 В
Solid conductor0.5 … 4 mm² / 20 … 12 AWG
Solid conductor, push-in termination1.5 … 4 mm² / 16 … 12 AWG
Stranded conductor0.5 … 2.5 mm² / 20 … 14 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points8
Total number of potentials4
Вес15.5 г
Ширина45.5 mm / 1.791 inch
На английском языке: Datasheet Wago 770-764
