Datasheet Wago 770-764/073-000 — Даташит
Защелкивающаяся розетка; 4-пол.; Код. B
TEST LEAD RESIST PRO M 1=1 PAIR | |||
770764 | 1 537 ₽ | ||
770-764 Wago | по запросу |
Actuation type | Operating tool Push-in |
Coding | B |
Цвет | light green |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | DE |
Degree of protection | IP20 |
Габариты: глубина | 36 mm / 1.417 inch |
Fine-stranded conductor | 0.5 … 4 mm² / 20 … 12 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² / 20 … 16 AWG |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² / 20 … 14 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 1.5 mm² / 16 AWG |
Fire load | 0.301 MJ |
GTIN | 4050821555780 |
Gehäuseblechstärke | 0.5 … 2 mm / 0.02 … 0.079 inch |
Height | 18.5 mm / 0.728 inch |
Locking lever | да |
Locking of plug-in connection | locking lever |
Marking | 1 ⏚ 2 3 |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Mounting type | Snap-in |
Nominal cross section | 4 mm² |
Note (strip length) | see also packaging or instructions |
Number of Poles | 4 |
Pin spacing | 10 mm (0.394 inch) |
Potential marking | 1 ⏚ 2 3 |
Rated current | 25 A |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 3) | 400 В |
Retention force of a plug-in connection | when locked: > 80N |
Solid conductor | 0.5 … 4 mm² / 20 … 12 AWG |
Solid conductor, push-in termination | 1.5 … 4 mm² / 16 … 12 AWG |
Stranded conductor | 0.5 … 2.5 mm² / 20 … 14 AWG |
Strip length | 9 mm / 0.35 Inch |
Surrounding air (operating) temperature | -35 … 85 °C |
Total number of connection points | 8 |
Total number of potentials | 4 |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 15.63 г |
Ширина | 45.5 mm / 1.791 inch |
Серия: 770 (100 из 608)
- 770-704 770-704/009-000 770-705 770-705/009-000 770-713 770-713/007-000 770-714 770-714/007-000 770-715 770-715/007-000 770-723 770-723/009-000 770-724 770-724/009-000 770-725 770-725/009-000 770-733 770-733/007-000 770-734 770-734/007-000 770-735 770-735/007-000 770-743 770-743/060-000 770-743/062-000 770-744 770-744/060-000 770-744/062-000 770-744/064-000 770-745 770-745/060-000 770-745/062-000 770-745/064-000 770-753 770-753/060-000 770-753/062-000 770-754 770-754/060-000 770-754/062-000 770-754/064-000 770-755 770-755/060-000 770-755/062-000 770-755/064-000 770-763 770-763/071-000 770-763/073-000 770-764 770-764/071-000 770-764/072-000 770-764/073-000 770-765 770-765/073-000 770-773 770-773/071-000 770-773/073-000 770-774 770-774/071-000 770-774/072-000 770-774/073-000 770-775 770-775/073-000 770-783 770-783/081-000 770-783/082-000 770-784 770-784/081-000 770-785 770-785/080-000 770-785/082-000 770-793 770-793/081-000 770-793/082-000 770-794 770-794/081-000 770-795 770-795/080-000 770-795/082-000 770-803 770-803/011-000 770-804 770-804/011-000 770-805 770-805/011-000 770-813 770-813/011-000 770-814 770-814/011-000 770-815 770-815/011-000 770-823 770-823/011-000 770-824 770-824/011-000 770-825 770-825/011-000 770-833 770-833/011-000 770-834 770-834/011-000
770764/073000, 770 764/073 000
