Datasheet Wago 770-765 — Даташит
Серия770
Модель770-765
Защелкивающаяся розетка; 5-пол.; Код. B
HANDHELD ELECTRODE, FOR SURFACE
7707652 834 ₽
7707656 406 ₽
Зенер
Россия и страны ТС
7707656 979 ₽
Эиком
7707657 009 ₽
Wago 770-765
Actuation typeOperating tool Push-in
CodingB
Цветlight green
Country of originDE
Degree of protectionIP20
Габариты: глубина36 mm / 1.417 inch
Fine-stranded conductor0.5 … 4 mm² / 20 … 12 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 1.5 mm² / 20 … 16 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 2.5 mm² / 20 … 14 AWG
Fine-stranded conductor with ferrule, push-in termination, from1.5 mm² / 16 AWG
Fire load0.312 MJ
GTIN4055143594370
Gehäuseblechstärke0.5 … 2 mm / 0.02 … 0.079 inch
Height18.5 mm / 0.728 inch
Locking leverда
Marking1 2 3 4 5
Mounting typeSnap-in
Nominal cross section4 mm²
Note (strip length)see also packaging or instructions
Number of Poles5
Pin spacing10 mm (0.394 inch)
Potential marking1 2 3 4 5
Product Group20 (WINSTA)
Rated current25 A
Rated voltage (III / 3)400 В
Solid conductor0.5 … 4 mm² / 20 … 12 AWG
Solid conductor, push-in termination1.5 … 4 mm² / 16 … 12 AWG
Stranded conductor0.5 … 2.5 mm² / 20 … 14 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points10
Total number of potentials5
Вес18.7 г
Ширина55.5 mm / 2.185 inch
На английском языке: Datasheet Wago 770-765
