Datasheet Wago 770-940 — Даташит
Распределительный соединитель с трех фаз на одну; 2 L2; 1 5-контактный штекер; 1 5-контактная розетка; 1 3-контактная розетка; 2 3-контактных розетки; 1 3-контактная розетка
| Coding | P |
| Цвет | red |
| Contact material | Copper or copper alloy, surface-treated |
| Contact type (pluggable connector) | Socket/plug |
| Country of origin | DE |
| Degree of protection | IP20 |
| Габариты: глубина | 62.75 mm / 2.47 inch |
| Fire load | 1.327 MJ |
| GTIN | 4045454548254 |
| Height | 41.1 mm / 1.618 inch |
| Locking lever | да |
| Locking of plug-in connection | locking lever |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 5 |
| Pin spacing | 10 mm (0.394 inch) |
| Product Group | 20 (WINSTA) |
| Rated current | 25 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated impulse voltage (III / 3) 2 | 4 kV |
| Rated voltage (III / 3) | 400 В |
| Rated voltage (III / 3) 2 | 250 В |
| Retention force of a plug-in connection | when locked: > 80N |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total number of potentials | 5 |
| Type of distribution connector | Three-phase to single-phase distribution connector |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 86.983 г |
| Ширина | 64.8 mm / 2.551 inch |
Серия: 770 (100 из 608)
- 770-855/011-000 770-855/011-000/060-000 770-855/011-000/062-000 770-855/011-000/064-000 770-855/060-000 770-855/062-000 770-855/064-000 770-863 770-863/011-000 770-863/011-000/071-000 770-863/011-000/073-000 770-863/071-000 770-863/073-000 770-864 770-864/011-000 770-864/011-000/071-000 770-864/011-000/072-000 770-864/011-000/073-000 770-864/071-000 770-864/072-000 770-864/073-000 770-865 770-865/011-000 770-865/073-000 770-873 770-873/011-000 770-873/011-000/071-000 770-873/011-000/073-000 770-873/071-000 770-873/073-000 770-874 770-874/011-000 770-874/011-000/071-000 770-874/011-000/072-000 770-874/011-000/073-000 770-874/071-000 770-874/072-000 770-874/073-000 770-875 770-875/011-000 770-875/011-000/073-000 770-875/073-000 770-883 770-883/011-000 770-883/011-000/081-000 770-883/011-000/082-000 770-883/081-000 770-883/082-000 770-884 770-884/011-000 770-884/011-000/081-000 770-884/081-000 770-885 770-885/011-000 770-885/011-000/080-000 770-885/011-000/082-000 770-885/080-000 770-885/082-000 770-893 770-893/011-000 770-893/011-000/081-000 770-893/011-000/082-000 770-893/081-000 770-893/082-000 770-894 770-894/011-000 770-894/011-000/081-000 770-894/081-000 770-895 770-895/011-000 770-895/011-000/080-000 770-895/011-000/082-000 770-895/080-000 770-895/082-000 770-901 770-902 770-903 770-907 770-909 770-911 770-912 770-913 770-921 770-922 770-934 770-936 770-940 770-944 770-945 770-951 770-952 770-953 770-967 770-970 770-974/076-000 770-977/076-000 770-992 770-993 770-994 770-995
