Datasheet Wago 770-1105 — Даташит
Серия770
Модель770-1105
Разъем; 5-пол.; Код. I
22 предложений от 8 поставщиков
, Cable Clamps and Clips Clamp Screw Propionate Amber 9.52mm
75 ₽
770-1105
от 1 064 ₽
Элитан
1 175 ₽
GG77011-05
Microsemi
Wago 770-1105
Actuation typeOperating tool Push-in
CodingI
Цветblue
Country of originDE
Degree of protectionIP20
Габариты: глубина37.5 mm / 1.476 inch
Fine-stranded conductor0.5 … 4 mm² / 20 … 12 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 1.5 mm² / 20 … 16 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 2.5 mm² / 20 … 14 AWG
Fine-stranded conductor with ferrule, push-in termination, from1.5 mm² / 16 AWG
Fire load0.257 MJ
GTIN4044918252706
Height12.9 mm / 0.508 inch
Locking leverнет
MarkingN ⏚ L DA- DA+
Mismating protectionYes
Nominal cross section4 mm²
Note (strip length)see also packaging or instructions
Number of Poles5
Pin spacing10 mm (0.394 inch)
Potential markingN ⏚ L DA- DA+
Rated current25 A
Rated voltage (III / 3)400 В
Solid conductor0.5 … 4 mm² / 20 … 12 AWG
Solid conductor, push-in termination1.5 … 4 mm² / 16 … 12 AWG
Stranded conductor0.5 … 2.5 mm² / 20 … 14 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points10
Total number of potentials5
Вес15.4 г
Ширина50 mm / 1.969 inch
7701105, 770 1105
На английском языке: Datasheet Wago 770-1105
