Datasheet Wago 770-1334 — Даташит
Серия770
Модель770-1334
Штекер; 4-пол.; Код. Q
Wago 770-1334
Actuation typeOperating tool Push-in
CodingQ
Цветgreen
Country of originDE
Degree of protectionIP20
Габариты: глубина37.5 mm / 1.476 inch
Fine-stranded conductor0.5 … 4 mm² / 20 … 12 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 1.5 mm² / 20 … 16 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 2.5 mm² / 20 … 14 AWG
Fine-stranded conductor with ferrule, push-in termination, from1.5 mm² / 16 AWG
Fire load0.252 MJ
GTIN4045454081393
Height12.9 mm / 0.508 inch
Locking leverнет
MarkingN PE1 PE2 L
Mismating protectionYes
Nominal cross section4 mm²
Note (strip length)see also packaging or instructions
Number of Poles4
Pin spacing10 mm (0.394 inch)
Potential markingN PE1 PE2 L
Rated current25 A
Rated voltage (III / 3)400 В
Solid conductor0.5 … 4 mm² / 20 … 12 AWG
Solid conductor, push-in termination1.5 … 4 mm² / 16 … 12 AWG
Stranded conductor0.5 … 2.5 mm² / 20 … 14 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points4
Total number of potentials4
Вес13.022 г
Ширина40 mm / 1.575 inch
7701334, 770 1334
На английском языке: Datasheet Wago 770-1334
