Datasheet Wago 771-6993/107-801 — Даташит
предв. собранный соединительный кабель; Eca; Розетка/открытая; 3-пол.; Код. A; H05VV-F 3G 2,5 мм²; 8 m
| 771-6993/107-202 Wago | по запросу | ||
| Coding | A |
| Цвет | black |
| Color of sheathed cable | black |
| Conductor preparation | tip-bonded |
| Connection type | Socket - free end |
| Connector color | black |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | DE |
| Cross section of single conductor | 2.5 mm² |
| Degree of protection | IP 2xD |
| Durchmesser der Mantelleitung | 9.2 … 11.4 mm |
| Fire load | 21.611 MJ |
| GTIN | 4050821523826 |
| Ground function | with preceding GND contact |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | L ⏚ N |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 3 |
| Pin spacing | 10 mm (0.394 inch) |
| Potential marking | L ⏚ N |
| Printing color of mating face | white |
| Printing color of sheathed cable | white |
| Printing color of strain relief | white |
| Rated current | 20 A |
| Rated voltage (III / 3) | 250 В |
| Reaction to fire class per EN 50575 | Eca |
| Retention force of a plug-in connection | when locked: > 80N |
| Sheath material | PVC |
| Strain relief color | black |
| Strip length | 55 мм |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 8 m |
| Total number of potentials | 3 |
| Type of cable | H05VV-F 3G2.5 |
| Type of cable assembly | Connecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 1299.508 г |
Серия: 771 (100 из 3186)
- 771-6993/016-701 771-6993/016-702 771-6993/016-801 771-6993/016-802 771-6993/017-101 771-6993/017-102 771-6993/017-201 771-6993/017-202 771-6993/017-301 771-6993/017-302 771-6993/017-401 771-6993/017-402 771-6993/017-501 771-6993/017-502 771-6993/017-601 771-6993/017-602 771-6993/017-701 771-6993/017-702 771-6993/017-801 771-6993/017-802 771-6993/106-101 771-6993/106-102 771-6993/106-201 771-6993/106-202 771-6993/106-301 771-6993/106-302 771-6993/106-401 771-6993/106-402 771-6993/106-501 771-6993/106-502 771-6993/106-601 771-6993/106-602 771-6993/106-701 771-6993/106-702 771-6993/106-801 771-6993/106-802 771-6993/107-101 771-6993/107-102 771-6993/107-201 771-6993/107-202 771-6993/107-301 771-6993/107-302 771-6993/107-401 771-6993/107-402 771-6993/107-501 771-6993/107-502 771-6993/107-601 771-6993/107-602 771-6993/107-701 771-6993/107-702 771-6993/107-801 771-6993/107-802 771-6993/116-101 771-6993/116-102 771-6993/116-201 771-6993/116-202 771-6993/116-301 771-6993/116-302 771-6993/116-401 771-6993/116-402 771-6993/116-501 771-6993/116-502 771-6993/116-601 771-6993/116-602 771-6993/116-701 771-6993/116-702 771-6993/116-801 771-6993/116-802 771-6993/117-101 771-6993/117-102 771-6993/117-201 771-6993/117-202 771-6993/117-301 771-6993/117-302 771-6993/117-401 771-6993/117-402 771-6993/117-501 771-6993/117-502 771-6993/117-601 771-6993/117-602 771-6993/117-701 771-6993/117-702 771-6993/117-801 771-6993/117-802 771-6993/206-101 771-6993/206-102 771-6993/206-201 771-6993/206-202 771-6993/206-301 771-6993/206-302 771-6993/206-401 771-6993/206-402 771-6993/206-501 771-6993/206-502 771-6993/206-601 771-6993/206-602 771-6993/206-701 771-6993/206-702 771-6993/206-801 771-6993/206-802
7716993/107801, 771 6993/107 801
