Datasheet Wago 771-8965/107-502 — Даташит
Распределительный соединитель с выбором фазы; свободный конец кабеля; 5-пол.; длиной 5 м; с изоляцией из ПВХ; Концы проводников, припаянные: 9 мм
| Цвет | white |
| Conductor preparation | tip-bonded |
| Connection type | Distribution connector with phase selection - free end |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | DE |
| Cross section of single conductor | 2.5 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 11.2 … 13.9 mm |
| Fire load | 19.445 MJ |
| GTIN | 4045454559748 |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 5 |
| Pin spacing | 10 mm (0.394 inch) |
| Rated current | 20 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 400 В |
| Reaction to fire class per EN 50575 | Eca |
| Retention force of a plug-in connection | when locked: > 80N |
| Sheath material | PVC |
| Strip length | 55 мм |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 5 m |
| Total number of potentials | 5 |
| Type of cable assembly | Connecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 1260.827 г |
Серия: 771 (100 из 3186)
- 771-8292/015-403 771-8292/015-405 771-8292/015-407 771-8292/015-503 771-8292/015-505 771-8292/015-507 771-8292/015-603 771-8292/015-605 771-8292/015-607 771-8292/015-703 771-8292/015-705 771-8292/015-707 771-8292/015-803 771-8292/015-805 771-8292/015-807 771-8292/016-103 771-8292/016-203 771-8292/016-303 771-8292/016-403 771-8292/016-503 771-8292/016-603 771-8292/016-703 771-8292/016-803 771-8292/115-205 771-8292/115-207 771-8292/115-405 771-8292/115-407 771-8292/115-605 771-8292/115-607 771-8292/115-805 771-8292/115-807 771-8292/215-203 771-8292/215-403 771-8292/215-603 771-8292/215-803 771-8965/007-101 771-8965/007-102 771-8965/007-201 771-8965/007-202 771-8965/007-801 771-8965/017-101 771-8965/017-102 771-8965/017-201 771-8965/017-202 771-8965/107-101 771-8965/107-102 771-8965/107-201 771-8965/107-202 771-8965/107-301 771-8965/107-501 771-8965/107-502 771-8965/117-101 771-8965/117-102 771-8965/117-201 771-8965/117-202 771-8982/005-101 771-8982/005-301 771-8982/006-101 771-8982/006-102 771-8982/006-103 771-8982/006-104 771-8982/006-201 771-8982/006-202 771-8982/006-203 771-8982/006-204 771-8982/006-301 771-8982/006-302 771-8982/006-303 771-8982/006-304 771-8982/006-401 771-8982/006-402 771-8982/006-403 771-8982/006-404 771-8982/006-501 771-8982/006-502 771-8982/006-503 771-8982/006-504 771-8982/006-601 771-8982/006-602 771-8982/006-603 771-8982/006-604 771-8982/006-701 771-8982/006-702 771-8982/006-703 771-8982/006-704 771-8982/006-801 771-8982/006-802 771-8982/006-803 771-8982/006-804 771-8982/007-103 771-8982/007-104 771-8982/007-203 771-8982/007-204 771-8982/007-303 771-8982/007-304 771-8982/007-403 771-8982/007-404 771-8982/007-503 771-8982/007-504 771-8982/007-603
7718965/107502, 771 8965/107 502
