Datasheet Wago 771-8982/106-603 — Даташит
предв. собранный соединительный кабель; Eca; Розетка/открытая; 2-пол.; Код. L; H05VV-F 2 x 1,5 мм²; 6 м
| 771-8982/106-101 Wago | по запросу | ||
| Coding | L |
| Цвет | dark gray |
| Color of sheathed cable | black |
| Conductor preparation | tip-bonded |
| Connection type | Socket - free end |
| Connector color | dark gray |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | DE |
| Cross section of single conductor | 1.5 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 6.8 … 8.6 mm |
| GTIN | 4055143474344 |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | L' N' |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 2 |
| Pin spacing | 10 mm (0.394 inch) |
| Potential marking | L' N' |
| Printing color of mating face | white |
| Printing color of sheathed cable | white |
| Printing color of strain relief | white |
| Rated current | 16 A |
| Rated voltage (III / 3) | 250 В |
| Reaction to fire class per EN 50575 | Eca |
| Retention force of a plug-in connection | when locked: > 80N |
| Sheath material | PVC |
| Strain relief color | black |
| Strip length | 35 мм |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 6 m |
| Total number of potentials | 2 |
| Type of cable | H05VV-F 2x1.5 |
| Type of cable assembly | Connecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 503.41 г |
Серия: 771 (100 из 3186)
- 771-8982/016-803 771-8982/016-804 771-8982/017-103 771-8982/017-104 771-8982/017-203 771-8982/017-204 771-8982/017-303 771-8982/017-304 771-8982/017-403 771-8982/017-404 771-8982/017-503 771-8982/017-504 771-8982/017-603 771-8982/017-604 771-8982/017-703 771-8982/017-704 771-8982/017-803 771-8982/017-804 771-8982/105-101 771-8982/105-102 771-8982/105-201 771-8982/105-202 771-8982/105-301 771-8982/105-302 771-8982/105-501 771-8982/105-502 771-8982/105-701 771-8982/105-702 771-8982/106-101 771-8982/106-102 771-8982/106-103 771-8982/106-104 771-8982/106-201 771-8982/106-202 771-8982/106-203 771-8982/106-204 771-8982/106-301 771-8982/106-302 771-8982/106-303 771-8982/106-304 771-8982/106-401 771-8982/106-402 771-8982/106-403 771-8982/106-404 771-8982/106-501 771-8982/106-502 771-8982/106-503 771-8982/106-504 771-8982/106-601 771-8982/106-602 771-8982/106-603 771-8982/106-604 771-8982/106-701 771-8982/106-702 771-8982/106-703 771-8982/106-704 771-8982/106-801 771-8982/106-802 771-8982/106-803 771-8982/106-804 771-8982/107-103 771-8982/107-104 771-8982/107-203 771-8982/107-204 771-8982/107-303 771-8982/107-304 771-8982/107-403 771-8982/107-404 771-8982/107-503 771-8982/107-504 771-8982/107-603 771-8982/107-604 771-8982/107-703 771-8982/107-704 771-8982/107-803 771-8982/107-804 771-8982/115-101 771-8982/115-201 771-8982/116-101 771-8982/116-102 771-8982/116-103 771-8982/116-104 771-8982/116-201 771-8982/116-202 771-8982/116-203 771-8982/116-204 771-8982/116-301 771-8982/116-302 771-8982/116-303 771-8982/116-304 771-8982/116-401 771-8982/116-402 771-8982/116-403 771-8982/116-404 771-8982/116-501 771-8982/116-502 771-8982/116-503 771-8982/116-504 771-8982/116-601 771-8982/116-602
7718982/106603, 771 8982/106 603
