Datasheet Wago 771-8982/207-103 — Даташит
предв. собранный соединительный кабель; Eca; Штекер/открытый; 2-пол.; Код. L; H05VV-F 2 x 2,5 мм²; 1 м
| 771-8982/207-804 Wago | по запросу | ||
| Coding | L |
| Цвет | dark gray |
| Color of sheathed cable | black |
| Conductor preparation | tip-bonded |
| Connection type | Plug - free end |
| Connector color | dark gray |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | DE |
| Cross section of single conductor | 2.5 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 8.4 … 10.6 mm |
| GTIN | 4055143427296 |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | L' N' |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 2 |
| Pin spacing | 10 mm (0.394 inch) |
| Potential marking | L' N' |
| Printing color of mating face | white |
| Printing color of sheathed cable | white |
| Printing color of strain relief | white |
| Rated current | 20 A |
| Rated voltage (III / 3) | 250 В |
| Reaction to fire class per EN 50575 | Eca |
| Retention force of a plug-in connection | when locked: > 80N |
| Sheath material | PVC |
| Strain relief color | black |
| Strip length | 35 мм |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 1 m |
| Total number of potentials | 2 |
| Type of cable | H05VV-F 2x2.5 |
| Type of cable assembly | Connecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 129.537 г |
Серия: 771 (100 из 3186)
- 771-8982/117-103 771-8982/117-104 771-8982/117-203 771-8982/117-204 771-8982/117-303 771-8982/117-304 771-8982/117-403 771-8982/117-404 771-8982/117-503 771-8982/117-504 771-8982/117-603 771-8982/117-604 771-8982/117-703 771-8982/117-704 771-8982/117-803 771-8982/117-804 771-8982/205-201 771-8982/205-501 771-8982/206-101 771-8982/206-102 771-8982/206-103 771-8982/206-104 771-8982/206-201 771-8982/206-202 771-8982/206-203 771-8982/206-204 771-8982/206-301 771-8982/206-302 771-8982/206-303 771-8982/206-304 771-8982/206-401 771-8982/206-402 771-8982/206-403 771-8982/206-404 771-8982/206-501 771-8982/206-502 771-8982/206-503 771-8982/206-504 771-8982/206-601 771-8982/206-602 771-8982/206-603 771-8982/206-604 771-8982/206-701 771-8982/206-702 771-8982/206-703 771-8982/206-704 771-8982/206-801 771-8982/206-802 771-8982/206-803 771-8982/206-804 771-8982/207-103 771-8982/207-104 771-8982/207-203 771-8982/207-204 771-8982/207-303 771-8982/207-304 771-8982/207-403 771-8982/207-404 771-8982/207-503 771-8982/207-504 771-8982/207-603 771-8982/207-604 771-8982/207-703 771-8982/207-704 771-8982/207-803 771-8982/207-804 771-8982/215-101 771-8982/215-102 771-8982/215-201 771-8982/215-202 771-8982/215-301 771-8982/215-302 771-8982/215-501 771-8982/215-502 771-8982/215-701 771-8982/215-702 771-8982/216-101 771-8982/216-102 771-8982/216-103 771-8982/216-104 771-8982/216-201 771-8982/216-202 771-8982/216-203 771-8982/216-204 771-8982/216-301 771-8982/216-302 771-8982/216-303 771-8982/216-304 771-8982/216-401 771-8982/216-402 771-8982/216-403 771-8982/216-404 771-8982/216-501 771-8982/216-502 771-8982/216-503 771-8982/216-504 771-8982/216-601 771-8982/216-602 771-8982/216-603 771-8982/216-604
7718982/207103, 771 8982/207 103
