Datasheet Wago 771-8985/007-703 — Даташит
предв. собранный межблочный кабель; Eca; Розетка - штекер; 5-пол.; Код. L; H05VV-F 5G 2,5 мм²; 7 m
| 771-8985/007-703 Wago | по запросу | ||
| Coding | L |
| Цвет | dark gray |
| Color of sheathed cable | black |
| Connection type | Socket - Plug |
| Connector color | dark gray |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | DE |
| Cross section of single conductor | 2.5 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 11.2 … 13.9 mm |
| Fire load | 27.112 MJ |
| GTIN | 4050821122562 |
| Ground function | with preceding GND contact |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | N ⏚ L N' L' |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 5 |
| Pin spacing | 10 mm (0.394 inch) |
| Potential marking | N ⏚ L N' L' |
| Printing color of mating face | white |
| Printing color of sheathed cable | white |
| Printing color of strain relief | white |
| Rated current | 20 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 400 В |
| Reaction to fire class per EN 50575 | Eca |
| Retention force of a plug-in connection | when locked: > 80N |
| Sheath material | PVC |
| Strain relief color | black |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 7 m |
| Total number of potentials | 5 |
| Type of cable | H05VV-F 5G2.5 |
| Type of cable assembly | Interconnecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 1758.531 г |
Серия: 771 (100 из 3186)
- 771-8982/216-703 771-8982/216-704 771-8982/216-801 771-8982/216-802 771-8982/216-803 771-8982/216-804 771-8982/217-103 771-8982/217-104 771-8982/217-203 771-8982/217-204 771-8982/217-303 771-8982/217-304 771-8982/217-403 771-8982/217-404 771-8982/217-503 771-8982/217-504 771-8982/217-603 771-8982/217-604 771-8982/217-703 771-8982/217-704 771-8982/217-803 771-8982/217-804 771-8985/006-103 771-8985/006-104 771-8985/006-203 771-8985/006-204 771-8985/006-303 771-8985/006-304 771-8985/006-403 771-8985/006-404 771-8985/006-503 771-8985/006-504 771-8985/006-603 771-8985/006-604 771-8985/006-703 771-8985/006-704 771-8985/006-803 771-8985/006-804 771-8985/007-103 771-8985/007-104 771-8985/007-203 771-8985/007-204 771-8985/007-303 771-8985/007-304 771-8985/007-403 771-8985/007-404 771-8985/007-503 771-8985/007-504 771-8985/007-603 771-8985/007-604 771-8985/007-703 771-8985/007-704 771-8985/007-803 771-8985/007-804 771-8985/016-103 771-8985/016-104 771-8985/016-203 771-8985/016-204 771-8985/016-303 771-8985/016-304 771-8985/016-403 771-8985/016-404 771-8985/016-503 771-8985/016-504 771-8985/016-603 771-8985/016-604 771-8985/016-703 771-8985/016-704 771-8985/016-803 771-8985/016-804 771-8985/017-103 771-8985/017-104 771-8985/017-203 771-8985/017-204 771-8985/017-303 771-8985/017-304 771-8985/017-403 771-8985/017-404 771-8985/017-503 771-8985/017-504 771-8985/017-603 771-8985/017-604 771-8985/017-703 771-8985/017-704 771-8985/017-803 771-8985/017-804 771-8985/106-103 771-8985/106-104 771-8985/106-203 771-8985/106-204 771-8985/106-303 771-8985/106-304 771-8985/106-403 771-8985/106-404 771-8985/106-503 771-8985/106-504 771-8985/106-603 771-8985/106-604 771-8985/106-703 771-8985/106-704
7718985/007703, 771 8985/007 703
