Datasheet Wago 771-8985/117-403 — Даташит
предв. собранный соединительный кабель; Eca; Розетка/открытая; 5-пол.; Код. L; H05Z1Z1-F 5G 2,5 мм²; 4m
| 771-8985/117-603 Wago | по запросу | ||
| Coding | L |
| Цвет | dark gray |
| Color of sheathed cable | black |
| Conductor preparation | tip-bonded |
| Connection type | Socket - free end |
| Connector color | dark gray |
| Contact material | Copper or copper alloy, surface-treated |
| Country of origin | DE |
| Cross section of single conductor | 2.5 mm² |
| Degree of protection | IP20 |
| Durchmesser der Mantelleitung | 11.2 … 13.9 mm |
| GTIN | 4055143497633 |
| Ground function | with preceding GND contact |
| Halogen-free | Yes |
| Locking lever | нет |
| Locking of plug-in connection | locking lever |
| Marking | N ⏚ L N' L' |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 5 |
| Pin spacing | 10 mm (0.394 inch) |
| Potential marking | N ⏚ L N' L' |
| Printing color of mating face | white |
| Printing color of sheathed cable | white |
| Printing color of strain relief | white |
| Rated current | 20 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 400 В |
| Reaction to fire class per EN 50575 | Eca |
| Retention force of a plug-in connection | when locked: > 80N |
| Strain relief color | black |
| Strip length | 55 мм |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total length | 4 m |
| Total number of potentials | 5 |
| Type of cable | H05Z1Z1-F 5G2.5 |
| Type of cable assembly | Connecting cable |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 928.793 г |
Серия: 771 (100 из 3186)
- 771-8985/106-303 771-8985/106-304 771-8985/106-403 771-8985/106-404 771-8985/106-503 771-8985/106-504 771-8985/106-603 771-8985/106-604 771-8985/106-703 771-8985/106-704 771-8985/106-803 771-8985/106-804 771-8985/107-103 771-8985/107-104 771-8985/107-203 771-8985/107-204 771-8985/107-303 771-8985/107-304 771-8985/107-403 771-8985/107-404 771-8985/107-503 771-8985/107-504 771-8985/107-603 771-8985/107-604 771-8985/107-703 771-8985/107-704 771-8985/107-803 771-8985/107-804 771-8985/116-103 771-8985/116-104 771-8985/116-203 771-8985/116-204 771-8985/116-303 771-8985/116-304 771-8985/116-403 771-8985/116-404 771-8985/116-503 771-8985/116-504 771-8985/116-603 771-8985/116-604 771-8985/116-703 771-8985/116-704 771-8985/116-803 771-8985/116-804 771-8985/117-103 771-8985/117-104 771-8985/117-203 771-8985/117-204 771-8985/117-303 771-8985/117-304 771-8985/117-403 771-8985/117-404 771-8985/117-503 771-8985/117-504 771-8985/117-603 771-8985/117-604 771-8985/117-703 771-8985/117-704 771-8985/117-803 771-8985/117-804 771-8985/206-103 771-8985/206-104 771-8985/206-203 771-8985/206-204 771-8985/206-303 771-8985/206-304 771-8985/206-403 771-8985/206-404 771-8985/206-503 771-8985/206-504 771-8985/206-603 771-8985/206-604 771-8985/206-703 771-8985/206-704 771-8985/206-803 771-8985/206-804 771-8985/207-103 771-8985/207-104 771-8985/207-203 771-8985/207-204 771-8985/207-303 771-8985/207-304 771-8985/207-403 771-8985/207-404 771-8985/207-503 771-8985/207-504 771-8985/207-603 771-8985/207-604 771-8985/207-703 771-8985/207-704 771-8985/207-803 771-8985/207-804 771-8985/216-103 771-8985/216-104 771-8985/216-203 771-8985/216-204 771-8985/216-303 771-8985/216-304 771-8985/216-403 771-8985/216-404
7718985/117403, 771 8985/117 403
